Question about Garden
How do I remove the whole trimmer head on troy bilt 70ss trimmer
4 Suggested Answers
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Posted on Jul 31, 2009
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do I remove the trimmer head from my TB32EC Troy Bilt trimmer to clear grass build up inside of plastic head?
Depending on the style of head, you either unscrew the cap on the end. of you push 2 clips in and pull the spool cover off.
Jul 14, 2015 | Troy Garden
How do you remove the cutting head from a troy-bilt tb525 ec 4 cycle gas trimmer?
ref: removing cutting head from troy-built trimmer tb525...
Just talked with Troy-Bilt company and got answer on how to remove head. seems that on the tb525, they used 3 heads over the production period. On mine, I had the slot above the head, but there was no deeper hole or notch to engage the screwdriver, etc. My head requires an allen wrench. Use the small part of the "L" shape and angle it into that notch...pointing the tip toward the shaft or engine direction. Then, hold the allen wrench upright and this will lock the shaft. Now you may turn the notched ring on the cutting head in a CCW direction (as you look from bottom to top). It will probably be very tight, but will come off. Hope this helps those who have been having trouble searching for that hole inside the notch that doesn't exist on this particular version. Good luck...
Mar 19, 2011 | Troy Garden
My troy-bilt 70ss trimmer head and or attachments stopped spinning. This is the third troy-bilt trimmer with this problem I have already exchanged two other trimmers within the first 30 days of purchase....
Considering your experience, if I was in your position I would locate the cause of the persistent failure and contact the manufacturer who might be suitably grateful.
I did that once with an inspection light that was bought in from China and brand engineered, as many goods are today, and I received a voucher and the company stopped buying that model. While it didn't help me much it would have helped others.
I am not familiar with the Troy-bilt brand which must be an exclusively US brand. I have used a MAC-60A for 30 years without many problems, a model reckoned by repairers to be a short-lived cheap consumer model.
Dec 01, 2017 | Troy Bilt Tb70ss Gas Trimmer
Jul 30, 2009 | Garden
How do you disasemble the head on the 4 cycle gas troy bilt trimmer
the head is bolted down by 4 torque bit screws some people call them star wrenches from the top but all plastic & carb needs to be removed more less everything to get to the bolts around the cylinder head as well as crankcase but to be honest its cheaper to buy a new one then repair it i had one repaired it & by the time i replaced everything i could have bought a new one cheaper then the parts cost me
Jul 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Jun 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Jun 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Jun 07, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
