Plug mp3 player into usb port comp shuts down
  • 2 more comments
  • Piza Jul 04, 2008
    When plugging Samsung YP-U3 in any USB port, the screen on MP3 player shows 'USB connecting', but after 10 seconds it shows 'Disconnected'. The charging facility is no problem, but the MP3 just cannot connect, and PC does not recognise the device. Hence I cannot upload any songs onto MP3.
    I followed instructions on Guide which says not to use a USB hub, and plugged it straight into computer, but to no avail.
  • pbonghez Aug 24, 2008
    I used my sandisk sansa e2000 for many months and had no probem but now this appeared: when i connect it to the computer it says "connecting", "writing" then "disconnected"....
  • blue ray Nov 17, 2008
    ditto on above. I suspect upgrades to software on my computer have caused the disconnect problem. Help pl0x?
  • Anonymous Feb 03, 2009
    When i plug my Samsung mp3 player in the USB port, the PC shuts down..why?
Buy a i pod
Posted on Nov 05, 2008
ME TOO I CANT GET MINE TOO DO ANYTHING BUT BRING UP THE SYNC MENU
Posted on Oct 11, 2008
My computer says the USB port connected to my mp3 is drawing too much power and has shut down the USB port. How do I get around this? I have a MacBook Pro.
It look that your player is drawing too much current from your Macbook Pro: it is rather unusual nowadays but does happen even with some USB external 2.5in drives!
Solutions:
1) Buy a USB Power Adapter Y cable that plugs into 2 usb ports on your Computer an thus allows double the current (shop around as they are expensive on Amazon but pretty cheap on Ebay)
2) Plug your player via a 'Powered' USB Hub that can provide higher current (from its 'own AC/DC power pack') to each USB port on the Hub
Hioe it helps!
Dec 28, 2009 | SanDisk Sansa Fuze MP3 Player
Comp not reconizing my mp3
how can i fix my hug mp3 is loading displayed pls .
Sep 04, 2009 | iLO (2 GB) MP3 Player
Help!!! computer won't recognize my new Coby 4GB mp3 to sync
ok you need to unplug the mp3 from usb port and then shutdown your computer properly then wen it is totally shut down turn it off at the wall and then back on the same thing happens with me you properbly just didnt shut your comp down properly last time you used it
May 06, 2009 | Coby MP-610 MP3 Player
I dont know hopw to charge it
thats because it doesn't charge plugging it in lets you sync files from your comp it runs on batteries open the usb cover then slide the bottom off to replace the battery.
Feb 27, 2009 | Nextar MA933A MP3 Player
Comp not recognizing mp3 device
Try a different usb port first, then try another computer (with a compatible OS, of course). If another computer will not recognize it, then the player is actually damaged.
Jul 02, 2008 | Samsung YP-K3 MP3 Player
Still messed up.
hi yes it should be in recovery mode when doing this
does the firmware tell you when to connect the mp3 player to computer once in recovery mode open firmware file then when it asks to connect then plug into your comp if it dont work this way then plug into comp before opening firmware file give this way a try also.
But the mp3 player needs to be in recovery mode whilst doing this
if this still dont work then try a different usb port failing this then their is a problem with either the cable or usb port or conection on mp3 check cable and connections at both ends make sure no dirt or paper is stuck in mp3 end ok
Let me know what happens ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
MP3 Shuts down when pluged in
try to turn it on before you charge it
Mar 22, 2008 | Audio Players & Recorders
Worked first then boot error now comp wont pick it up
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Jan 31, 2008 | RCA OPAL M4001 MP3 Player
Usb connection
I had this problem a couple of times. Turned out the battery didn't have enough juice. At least that's what worked for me.
Aug 15, 2006 | Motorola M500 MP3 Player
114 people viewed this question
 Grubhead
Grubhead
