I want to know how the mobile phones are integrated with a wifi during manufacturing?
SOURCE: how to install a themes for my motorola L7
To install themes on your l7 you will first have to download skinman and p2k drivers try the latest one (you can search for these softwares in google) In your phone change the default USB settings as data & fax connection then connect your phone to a usb port to which you had never conected your phone before then you will get a message that a new hardware is found select to "install now" then select "Install from a specific location" tick the "include this location in search" click "briowse" and select the p2k drivers folder that you had downloaded. For example "D:\Motorola System\p2kdrivers_2.9" Then click "next". It will install your phone. Then again you will get the same kind of message do the same for all until it says your phone has been installed and is ready for use. Now you have done half of the job. Now run Skinman the file list will be loaded. select install.You will get a message just select ok then browse and find the theme that you want to install then select open the theme will start installing. once you have added the desired number of themes select restart phone. now you are done.
SOURCE: Installing application on chinese mobiles
it is difficult to install software in chinese phone.Because most of them has a pirated IMEI code.If you want to install software,you are better to need help from the autherised service center.
SOURCE: how to install games/software in lg kg300 mobile phones
go to LG site and start downloading
www.lgmobile.com
SOURCE: I do not know the
My Dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: how to install wifi to my mobile phone samsung gt
how to install wifi to my phone samsung gt s3370
