Question about Dryers
I have a Miele T1413 dryer. It stopped working this morning. Light stuck in Anti-crease. Could not select another program or option. Please help.
  • binwu247 Apr 19, 2008
    it is only one year old ... just passed MFG warranty.
    I don't know how to reset the dryer. I tried to turn off the power and turn it back on. No use.
    I have a Miele Dryer T1413. It stopped working. Light stuck in "Anti-cease/End". I could not select any other program or option. I noticed that when door is closed, the internal ligtht is still on. I think the door lock/switch/sensor is bad. How do it check the door lock/switch/sensor? How do it take it out? Anyone knows the part I may need to replace it?
    Thanks,
    Genius:
  • 1,142 Answers
F your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Apr 19, 2008
    Brigadier General:
  • Dryers Master
  • 3,614 Answers
An check for the broke fuse in the interlock switch. if you were not an authorized service men for that its not advisable to to do it on your own..
  • Dryers Master
  • 13,433 Answers
Have you tryed to unplug the dryer.
The parts catalogue can be found the service manual of the product. Althought I have no idea witch parts would need to be replaced.
    Sergeant:
    Champion:
  • 427 Answers
If all of the buttons have frozen, is there a way to reset the washer? If not, how old is the washer, maybe after years of hard use it is time to buy a new one?
  • Michael Lake
    Michael Lake Apr 19, 2008
    Could you contact the manufacturer to see if there was a was to check these things. Maybe a plug or component became loose and fell out. Make be an cheap and replaceable item went bad.
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
Anti crease light stuck on and dryer won't work. Have tried power off for 24 hours, but still stuck.
Sounds to me like a logic board problem. 24 H power down would have fixed any transient problems. So it is a hard failure This means a sensor, or a processor failure. I think it is a processor board.
Good Luck,
Pete
Aug 27, 2015 | Miele Novotronic T220 Electric Dryer
Hi - miele dryer won't heat up and the anti-crease light is flashing when I select any programme. Have replaced the NTC sensor but it hasn't made any difference. Can anyone help? thanks
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Mar 21, 2015 | Miele Dryers
Flashing rinse light on meile 864 and anti crease/ finish light comes on.
If you are sure that you made no mistake in mounting the brush cap back on the motor (check the four pins), most probably the electronic EL200 is defective.
This happens often in this type of machine when the shock absorbers are worn (after 10 years).
You can check this by measuring the continuity in the little 6.3A fuse that is on the EL200. If it is blown, you may get the PCB repaired for 55 Euros + shipping (see link below). You also have to replace the shock absorbers (32 Euros) to get a full year guarantee.
Miele Reparatie EL200
Feb 11, 2014 | Miele W864 Front Load Washer
Anti crease light flashing, keeps stopping and beeping
Check the dryer vent to see if it is free and clear.
Jan 26, 2014 | Miele Dryers
The dryer is showing anti crease on the LCD. What can i do to reset or fix the problem.
have you tried disconnecting the power for about 15 minutes to see if it clears
anti crease refers to the dryer continuing to tublme for about 10-15 seconds every 5-10 minutes so when cycle is complete the clothing doesnt just set there where wrinkles can set in ,it tumbles after end of cycle to prevent wrinkling
Jul 22, 2011 | Miele Novotronic T1515A Electric Dryer
Meile W 844 Drum not turning
Its probably the motor brushes you need to replace them
May 10, 2009 | Miele Novotronic W1918A Front Load Washer
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Hi - we have a Miele T284 tumble drier which is 2 weeks old and seems to have developed a fault. The machine stops after about 30 seconds with the buzzer going and Finish/anti crease light on. This is...
if this unit is only two weeks old,its safe to say its under warranty ,if you can't remedy this yourself by consulting the owners manual,contact the place of purchase &/or the manufacture,i'm sure they will be glad to repair or replace the dryer.any attempt by you or any unqualified person to repair this will void your warranty.hope this helps.thanx for using fix-ya
Nov 25, 2008 | Miele Washing Machines
Dryers Logo
185 people viewed this question
Top Dryers Experts
