Question about Fagor Washing Machines
Fallo F07 lavadora fagor - Fagor Washing Machines
4 Suggested Answers
SOURCE: tengo un problema con mi lavadora whirlpool duet
ke tal tengo una lavadora whilpool duet pero al encenderla y poner el ciclo de lavado normal me prtecenta una falla dice falla 11 y no se que es esta falla me podria orientar?
elrayo_0609@hotmail.com gracias
Posted on Jun 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: fagor, washer dryer , model 2F-3611 flashing
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
  • 6277 Answers
SOURCE: our fagor fwm714it washing machine
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 27, 2011
Hot point ariston aqualtis condenser dryer fault code f07
F07
Heater relay stuck
Check wiring
Check electronic control PCB
Jun 21, 2014 | Hoover Dryers
Need manual for fagor splendid
Here is the manual for the Fagor Splendid Pressure cooker!
http://www.hippressurecooking.com/fagor-splendid-pressure-cooker-manual/
Jan 13, 2013 | Fagor Elite/splendid Helper Handle
Lavadora kenmore osasis he, pierde agua por abajo
tengo un problema con mi lavadora kenmore elite oasis he q cuando la prendo me aparese un 60 y ah se queda ????
Feb 29, 2012 | Kenmore Oasis HE 27082 Top Load Washer
Our fagor fwm714it washing machine door will not open after the cycle finishes or when turned off. the machine has been showing the error code F07 of late.
John C
Feb 27, 2011 | Fagor Washing Machines
Como abrir la lavadora LG pues no habre
A lavadora tem uma trava na porta, tem que apertar.. e aii sim puxar para abrir.
Apr 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tengo un problema con mi lavadora whirlpool duet cuando la enciendo para lavar me presenta un fallo en la pantalla. y sale fallo 22.que es el swich de la tapa.pero se lo cambie por uno nuebo y sigue...
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tengo una lavadora LXR7144EZ1 Empezo con un ruido
Mil gracias por tu ayuda, la lavadora cuando llena no hace ningun ruido, luego cuando empieza a restregar empieza un ruido fuerte y despues de esto se detiene por completo, muchas veces a trata de llegar al ciclo de exprimido. Pero el dia de ayer dejo de funcionar completamente.
Sep 01, 2009 | Whirlpool Washing Machines
Fagor, washer dryer , model 2F-3611 flashing code F07 can you tell me what this is please
Jun 12, 2009 | Washing Machines
Washing Machines Logo
621 people viewed this question
Top Fagor Washing Machines Experts
Vernon Taylor
ray gallant
Are you a Fagor Washing Machine Expert? Answer questions, earn points and help others
