Question about Stokke Xplory Standard Stroller
The height adjuster of my sotkke xplory is not working. Any suggestions?
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
How can i fix my stokke xplory brake
Hi David
We would recommend you contact Stokke for assistance
Welcome to Stokke
Jun 18, 2014 | Stokke Xplory Stroller
What age does the stokke xplory go up to
The Xplory is suitable up to 15kg, which is around three and half years old.
Hope that helps.
Apr 19, 2011 | Stokke Xplory Stroller
Where can I get a replacement Stokke Xplory footrest clip
Hi you could try Karlisles Pram Fix in Sydney. They do most Stokke parts. You can order parts for interstate via email and phone. There details are at:
www.karlisles.com.au
info@karlisles.com.au
They also might be able to refer you to a local supplier in QLD.
Hope that helps.
Jun 02, 2010 | Stokke Xplory Standard Stroller
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Manual Stokke Xplory needed
If you visit www.stokke.com you will be able to download the user manual.
Hope this helps.
Jan 31, 2010 | Stokke Xplory Stroller
The right front wheel of the xplory is stiff
Was your Xplory purchased new?
If so Stokke give a 3 year warranty on the Xplory. Get in touch with the shop you purchased it from of Stokke Direct.
If you didnt buy brand new, then apart from a little WD40 i dont really know the solution.. anyone else help?
Mar 23, 2009 | Stokke Xplory Stroller
Seat Unit Dropping Down the Chassis
Stokke has been contacted about this problem a few times and they offer a replacement piece that you insert yourself so that the system does not descend and it will be secured tighter. Just call them or email them...they are very good about helping you out with these problems even if your stroller is second-hand or no longer under warranty. Their Customer Service is amazing!
I own a Stokke Xplory Stroller too...and although I have not had this problem...I know about it.
From Fellow Mom.
Mar 03, 2009 | Stokke Xplory Stroller
Height adjustment
You'll have to turn the upright to its side to show the sole plate where the rolling brush is. Check where the front wheels are located and ensure there is no blockage obstructing the rotary dial. Sometimes the spring mechanisms can work themselves loose.
Inevitably you'll have to remove the sole plate and/or the rotary dial which may be screwed down. If it has cracked then you may have to seek a replacement.
Dont forget to rate this suggestion.
May 25, 2008 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
Stokke Xplory seat falling
Please contact your nearest Stokke agent or the place you purchased the stroller.They will supply the necessary part for the sliding problem.It's very easy and would not take too long.
Dec 06, 2006 | Stokke Xplory Standard Stroller
Stokke Xplory Standard Stroller Logo
48 people viewed this question
Top Stokke Baby Gear Experts
Dorel UK
Dorel UK
ray gallant
Are you a Stokke Baby Gear Expert? Answer questions, earn points and help others
