Question about Canon i9900 InkJet Photo Printer
My i9900 flashes a orange light 5 times, printer wont do nothing at all.
  • 1 more comment
  • tyronesnoop Jul 10, 2010
    my i9900 flashes a orange light 5 times, printer wont do nothing at all.
  • Canon Master
  • 4,737 Answers
Your problem is related to two issues,
1. Print Head problem 2. Waste Ink Tank full.
Let's start with the manual cleaning, remove all the cartridges, switch off the printer and leave Off after disconnecting the usb cable and the power cord. Clean all the print heads and contact points of the cartridges. Also clean the contact points on the printer. You can use a soft brush or piece of cotton ball dipped in acetone/spirit/alcohol, and wipe the print heads gently, you need to be careful otherwise you may damage them. Do the same with the contact points.
Now check the waste ink tank, you can just open the top cover and look, wrap a small piece of cloth on the tip of a screwdriver of and clean it. (do as you please, if you can clean it, that's enough). Even if you can't put the screwdriver inside, just clean the area, that'll be helpful [if you know how to open the waste ink tank, that's very much better].
Now reconnect the power cord, {switch On the adapter from the Mains}, press the Resume Button and the Power button, keep holding for few seconds and release the Resume Button [don't release the power button], again press the Resume Button twice and then release both the buttons. You'll see the Green Light blinks and right after green light stops blinking, press the Resume button several times. Again press the Power button, and now you can power it On normally, and right after it's On, install the cartridges and check the outcome.. Hopefully it works....
If in case this doesn't fix, you need to change the print head or replace the cartridges, if you have another spares, that'll be very much helpful, try installing them. Definitely your problem will be fixed.
I hope the first trick will do the game, and I wish you good luck.
If you have problem, please let me know.
Good luck.
Thanks for using FixYa.
Posted on Jul 10, 2010
  • 6,993 Answers
the problem is from the print head. The print head is the reason its flashing 5 times.
Remove the printer head from the printer, clean it and fix it back into it. This should fix the problem
But, if that doesn't solve the problem, let me know. Basically, the fault is from the print head, this problem is common with cannon i9900.
Good luck.
    i've done that, took out all cartriges, turned the printer off, everything I can think off
  • Walesarumi
    Walesarumi Jul 10, 2010
    Hello.
    pop out the print head, and clean it with alcohol . Force in some alcohol through the nozzles. Submerse it in warm
    water for five minutes, blot it dry and use some q-tips to dry
    around the nozzles. Let it sit for ten minutes or so to be sure it is dry, and then pop it back in the printer and make sure your cartridge is well fixed.
    You should as well do a deep cleaning. Then I print a test page.
    If the problem is not still solved, then you will have to replace your canon i9900 print head. Once print head is replaced, problem would be solved.
    Good luck.
    Genius:
  • 1,040 Answers
visit to the given link. same problem and solution there of has been posted there....
http://www.fixyourownprinter.com/forums/printer/45038
Hope this has helped you.. Thanks....
  • 4,281 Answers
Turn off the printer and pull ink cartrdiges from it.
Make sure there is not any paper jam all small paper pieces inside the printer and ink cartridges are fine.
TRy with another ink cartrdiges if you have.
Reset all settings of printer to defaults.
You can RESET all settings with menu button .
Let me know if you need further assistance.
Canon i9900 light remains orange
This is a serious problem, most likely it would be cheaper to buy a new printer that to try to get it repaired.
Aug 19, 2012 | Canon i9900 InkJet Photo Printer
Cannon i9900, power light is flashing green to orange
Come back to me with the flash sequence of both lights. that tells you what is wrong. Its more accurate than any error code.
May 28, 2011 | Canon i9900 InkJet Photo Printer
Canon i9900, orange light blinks 5 time upon start and continues to blink the same
This error mean "the print head is failed".You need to replace the print head.It's part number is QY6-0055.
Nov 19, 2009 | Canon i9900 InkJet Photo Printer
Pixma i9900 orange light flashes 5 times
hi guys,
Flash in orange 5 times indicates that the printhead is faulty so that the printer cannot detect the printhead. Rarely, faulty logic board and carriage unit may cause the same problem.
Regards,
Source:
Canon Inkjet Forum
Dec 13, 2008 | Canon i9900 InkJet Photo Printer
I have a cannon i9900, it has always worked perfectly. For the past week I can not print anything. I reinstalled software today still down, I see one green light followed by 5 yellow flashes (keeps...
Dear Bill,
Flashing 5 times in orange indicates that print head error occurs so it cannot be detected properly by the printer. To make it sure, install a good print head in the printer. Is the problem fixed?. If the problem still persist, carriage part may be faulty. Overall, the print head is the most faulty part in this case. So, you need to replace the print head with new one.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Cannon Office Equipment & Supplies
Canon i9900 Error reads as follows. Operator error. Press printer’s RESUME button. If this doesn’t clear the error, cancel printing and turn the printer off and then back on. I've cycled through...
there is something inside the printer, i have the same problem and that was it, a paper or something blocking the headprint to run from right to left
Oct 22, 2008 | Office Equipment & Supplies
I9900 printer wont print. power flashes 1 green 5 orange - printer head problem- I don't know where the original booklet is and don't know how to reinstall the printer head
this problem was NOT FIXED by your representative - quite the opposite - I fixed it myself - I believe a refund is due on my inital investment with you .
Ray Sands 9-18-08
Sep 17, 2008 | Office Equipment & Supplies
New logic board installed cant install driver
After installing a new i9900 logic board, you *must* configure the destination country setting. The default setting is probably for Japan (PIXUS 9900i):
1. With the printer powered off, hold down the resume button and press the power button.
2. While holding down the power button, release the resume button and press the resume button two times. Now release the power button. The LED will blink green and remain lit in green. You are now in Service Mode.
3. Press the resume button 5 times to get to Model Setting mode. The LED will turn orange. Then press the resume button two times to set the model number to i9900 (LTR). Press the power button once to lock in this setting and turn off the printer.
Apr 14, 2008 | Canon i9900 InkJet Photo Printer
I have a i9900 and the yellow light blinks 5 times
this link might help. Be sure to read the whole thing! http://www.fixyourownprinter.com/forums/inkjet/15284
May 14, 2007 | Canon i9900 InkJet Photo Printer
Canon i9900 InkJet Photo Printer Logo
1,502 people viewed this question
old marine
old marine
