Question about Acer Aspire One PC Notebook
My Touchpad wont work
When i start up my Computer the touchpad works for five seconds then i keep moving my finger but the actual mouse on the screen doesnt move... please help i dont know why
    Sniper:
  • 63 Answers
The problem may be with the touchpad drivers.Please update it or reinstall it
Posted on Jul 10, 2010
Touchpad drag and drop from surveys
This can be accomplished a couple of ways. Depending on the model of your computer there may be a pressure sensitive switch under the mouse pad that pressing a little harder will actuate. Another method is there might be 'virtual' mouse buttons on your trackpad. Put one finger in the flower left corner and drag on the pad with another. Finally, there is a setting for a double click drag and drop. Tap the mouse pad twice and on the second tap keep your finger on the pad and move it. Good luck!
Apr 04, 2014 | Acer Aspire 5720-6661 Notebook PC
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
How do i get screen out of power save mode
If you have a desktop then just move the mouse. If it is a wireless mouse you have to press the left button first. If it is a laptop move around on the touchpad with your finger, if you left the laptop lid open then you may have to press you power button for a second to get it to come back on. Please rate my answer so I am awarded points for it.
Jan 23, 2012 | Computers & Internet
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | Computers & Internet
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
My acer 5532 touchpad has suddenly stopped working... any ideas? mouse doesnt move and usb wireless mouse doesnt work either.. although it does on myu sister's laptop
Thanks. The Fn F7 idea did not work, the Enable/Disable toggle in Control Panel made no difference BUT the simple pressing of the TINY finger pointing next to the power button DID work. Duh!
Nov 15, 2009 | Acer Computers & Internet
Mouse touchpad, keyboard, and usb drives will not work
One thing you can try (for the touchpad)
Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
Hope that helps for your touchpad
May 05, 2008 | Acer Aspire 3000 Notebook
Touchpad is not working - TOSHIBA Satellite A135-2386
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Mar 19, 2008 | Toshiba Satellite A135 Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
i have latitude c610 and same problem happens with me too. i think that happens when i finish my brakfat and without cleaning my hands start using the touch pad. what happens according to me is that small particles of food(eg bread/dust particles) stuck in the corners or the body wall where the touch pad ends and keeps pressing the touchpad, thus causing the mouse to move to one direction. when i clean the corners and sides of the touchpad, it starts working ok !!
thanks
Johal
Dec 12, 2007 | Dell Latitude C610 Notebook
Acer Aspire One  PC Notebook Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
