Question about VeriFone VX510
I have a Verifone wireless credit card machine. VX610. Upon running card through I get error Host Conn Error:1009 I can't find a manual with troubleshooting tips
Have digital service will not work
Posted on Aug 04, 2010
  • daryl59 May 05, 2014
    Let's look at this again. The OP stated VX610 "wireless" but what does that actually mean? Wireless indicates no wires- what kind of comms then? if it is "true" wireless, then it connects via cellular towers. You will need to get with your pmts provider to fix the cellular connection, or possibly the cell signal in that location is not strong enough, or if it is CDMA, it could need to be freshly OTA'd. There are several scenarios. You can see why conacting your pmts provider might indeed help. (If via WiFi, that's different in many ways, and there are some pretty good answers already posted)
    New Friend:
I have a vx510 and had the same problem. A storm came through last night, and this morning when I ran the first card, I had the same TCP 1009 error. I always start with the simple solution first. I unplugged the ethernet and power lines, waited a few seconds, then plugged the ethernet line in, and then the power. It worked fine after that.
Posted on Jan 31, 2013
  • owner368
    owner368 Jan 31, 2013
    Problem Solver:
  • 8 Answers
You would need a digital to analog converter. These can be bought almost anywhere. Another option is to ask your phone company to install a dedicated analog phone line for your credit card terminal. These are the only options or going with a IP terminal.
Posted on Jul 15, 2011
I think there might be a problem of DHCP (Dynamic host configuration protocol). Check your DHCP connection. You are getting network error message while you process credit card. A network error might prevent the DHCP client from sending messages to the DHCP server.
_____________________________
credit card online processing
Posted on May 28, 2012
  • VeriFone Expert
  • 113 Answers
The Local DNS Server is unable to translate the IP location.solution: Change the "#HOSTIP" parameter field from 'opticard.optinc.com' to '66.179.134.151' and the "#PORT" parameter should remain '443'.
Posted on Nov 21, 2011
    Problem Solver:
  • 7 Answers
It is somewhat problematic to have a dial up terminal on a digital line. You will get as many opinions as the number of people you ask, but my recent experience with these situations is this: First, you should get with your digital phone service provider and make it clear to them that you are having trouble that did not occur before switching to them, and that they must assist in resolving the issue for it to be possible for them to retain your continued business. Tell them you require that line to be set up as "a fax line that holds the connection for an extended period" . 2 points-FAX line & EXTENDED PERIOD. I don't know what it is, but that's what we had to have done to ours to work. And it does-every day I download, test and verify dial up functionality on Hypercoms, Verifone Tranz and Vx---, FD---, Nurit, Dejavoo you name it. Every day. So-it can be done, but you have to get it set up correctly.
Posted on Apr 13, 2011
VeriFone VX510 TCP error 1009
your internet connection is not established check internet and Ethernet cables. may have to reboot your modem
Jan 27, 2014 | VeriFone Omni VX-510 Credit Card Machine...
Tip
Verifone error messages
Troubleshooting any Verifone product by any third party company including Fixya.com doesn't provide any support for any error messages. It is a credit card machine and I'm sure for security reasons it was purposly done that way.
You can contact Verifone at:
1-800-834-9133
Mon-Fri 8 a.m. to 7 p.m. EST
Manuals are available at this link
on Sep 02, 2008 | VeriFone (M19755014US1) Magnetic Card...
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
How do I reboot verifone vx610?
UNLESS YOU DROPPED THE TERMINAL, THIS CONDITION IS CAUSED BY A DEPLETED INTERNAL BATTERY, WHICH MUST BE REPLACED fix Verifone TAMPER message for $32. Free return shipping
Apr 04, 2012 | VeriFone VX 610 Credit Card Terminal...
RAM CHKSUM ERROR ON VX610 TERMINAL I : commsvr. out Any Idea what is the issue. When I press F4 it say system error call customer service
Maybe you have a corrupted softpay system, call you credir processor to reload it. An secondly your GPRS/Radio board maybe bad too. Call (775)358-2922 look for randy maybe we can help. thanks
Nov 12, 2011 | VeriFone VX 610 Credit Card Terminal...
Hi. i own a verifone vx610 wireless credit card machine and I'm getting the TAMPER message on the screen. is there anyway the fix this problem. thank you
if you still need help with your Vx 610 we can help you call (775) 358-2922 ask for Randy and YES we can fix the TAMPER error. Thanks
Jul 15, 2011 | VeriFone VX 610 Credit Card Terminal...
When I power up the Verifone vx610, it says Application SPPAYM is not responding to VMAC. What do I do?
I think you have a flashing TAMPER MESSAGE in your machine or better yet you have a corrupted program that needs to be reloaded with the help of your credit card processor. If you still need help you call us in this number (775)358-2922 and ask for Randy. Thanks.
Jul 12, 2011 | VeriFone VX 610 Credit Card Terminal...
I need a download for an operations manual for a verifone vx610
The link below should be what you need.
http://office.manualsonline.com/manuals/mfg/verifone/vx_610.html
Mar 17, 2011 | VeriFone VX 610 Credit Card Terminal...
Verifone vx610
#1 You need the Vmac and Comserv applications that were deleted when you cleared memory in order to perform an IP download. Without them you can only perform a dial only download.
#2 The programming for your VX510 will not load in your VX610 because they doth identify to the server as different models. If you did get the vx610 to connect and request your vx510 file you would only recieve an error "Application not configured" or "file not found"
Pro Tip: You can still clone VX terminals reguardless of model with the correct cable. Enter system mode and press 0 the # or 0 then * to send and recieve. This would put the application from the vx510 into the vx610 but your vx610 may not work through a com method other than dial depending on your processor.
Feb 10, 2010 | Computers & Internet
Verifone vx610 decline code 248
This is tricky to answer... different processing service use different codes. If the software you are running is built on a St. Pete's platform, this code means that the transaction you were processing was a 'reversal' (void) and the amount entered didn't match the original.
If you were running a sale and received this code and the display or receipt actually printed "declined" - it is a valid response indicating the customer card was declined and the code tells the service rep at your processing center why it was turned down (over limit, high risk, frozen account, etc...). If the response did show the word "declined", you can call your customer service department for your processor and they should be able to tell you what the code means in their system. If they don't - change processors as this is a standard service.
Aug 25, 2009 | VeriFone VX510
VeriFone VX510 Logo
3,633 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Marvin
Marvin
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
