Question about Thomson 30LCDB03B 30 in. HDTV
I have pressed lock ,on my Thomson LCD 30 and I now cant turn it on .I have no remote control
  • 2 more comments
  • kevinlawless Jul 10, 2010
    is there a entry code for programming, entry to a Thomson scenium LCD 30 .to use a remote control
    I still cant turn the unit on
    where in Perth Australia can I get one
    CAN ANYONE TELL ME THE CODE TO OPEN , A THOMSON 30 LCD BO3BBK
    REGARDS KEVIN
  • 10,515 Answers
You need to enter the menu to get it Reset and that is only possible using a remote.
Unfortunately, if that is the child lock or lock symbol appears, there is no way round than buying a remote and getting it fixed ASAP.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 10, 2010
  • taran_2005
    taran_2005 Jul 10, 2010
    Thanks for your response!!
    In order to get the code removed, you need to go to menu option. As it cannot be accessed directly by your TV, you need to look for a remote for this TV. I have checked with most of the online vendors and as of now, they do not have the remote for this Model.
    You need to search it from the TV repair parts nearby your town. Other than this there could be a couple of options, but for those, you need to call technicians.
    I wish i could have a better solution.
    Hope i helped you.
  • Thomson Master
  • 5,138 Answers
Try this,with TV turned off Press and hold at same time ch- and vol- untill tv comes on this should put you in factory settings reset.
  • ladywinn
    ladywinn Jul 10, 2010
    Thomson is RCA and that it the service code to enter factory settings ,Some times unpluging set wait 5mins and then pluging back up will reset. You could also have some bad capacitors in power supply causing set not to come back on ? Bad capacitors will be swollen,vented or puffed up on top
    they are to all be flat as a board on Top not vented or swollen. 1000uf 16v 220uf 10v 3300uf 10v caps.
  • ladywinn
    Look on website Mats Electronics 1-800-628-1118 and Partstore.com1-866-925-7278
    Is your TV showing at bottom or Top Parental LOCK?
  • Thomson Master
  • 11,800 Answers
By design when the tv is locked you can turn it on only with a remote. Your only option is to buy one and use it. Reseting the tv isn't an option since this is available only thru the menu.
  • 1 more comment
  • Azrael SRL Jul 10, 2010
    No, there is no code or command that can reset the tv when only the buttons on it are used. To unlock the tv with the remote all you need to do is to start it and remove the Lock by unticking the corresponding box from the Menu - Preferences.
    If you will be buying a universal remote , it will come with it's own set of codes that you will need to manually input in the remote to program it.
    A universal remote can be found at all shops that sell electronics. Since there are a lot of models and types check first that the remote you intend to buy does support Thomson televisions - not all do. Best option would be to buy a programmable remote (like the ones from Logitech, that can be bought online) but these will be expensive; on the other hand if you take care of it it will be the last remote you'll ever buy, it will work with absolutely every device you could buy in the future.
    THERE IS NO CODE TO OPEN YOUR LOCKED TV, ALL YOU NEED IS A REMOTE TO START IT - JUST PRESS ON ANY CHANNEL BUTTON , THAT IS ALL.
How can i start my thomson tv without remote
? All TV's come with a button (on the TV) to turn the TV on.
Nov 05, 2014 | Thomson Televison & Video
Hi the child has put a lock on my tv and now I cant manually change channels or volume how do I manually take lock of thomson tv
You'll probably need to use the remote control to access the TV's settings menu to deactivate the child lock feature.
Oct 15, 2014 | Televison & Video
I was wondering if anyone could help in two problems the codes for thomson DTI6300 pvr box and a time 32" lcd L220 tv to be used with the jumbo universal remote. thanks in advance keith
Here is a link to the codes, but I suspect you already have them and your devices aren't listed.... http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
So, you can manually code your jumbo as follows;
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
Jan 06, 2010 | Universal Remote Control Remote Control
Remote control code swisstec 30in lcd tv
IF YOU CANNOT FIND A CODE THAN MOST LIKELY THERE IS NOT A CODE FOR THE TV AND WILL NOT BE SUPPORTED
Jan 24, 2009 | Connect3D Radeon X800 / 256MB GDDR3 / PCI...
How to unlock my Thomson 28DP45EG?
Press the TV button on the remote controller!
Nov 22, 2008 | Televison & Video
We have lost the remote and the television is on sleep/standby so i cant turn it on
Found thomson website for remote controls was able to order a new one 12 99 no postage Thanks
Oct 12, 2008 | Thomson Televison & Video
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Thomson 30LCDB03B 30 in. HDTV Logo
145 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
