Question about Bose 3·2·1 II System
Bose life style 48
I just bought a Bose life style 48... and i have a big selection on DVD's but 90% of the DVD's will not play yet they are all supported by the Bose system according to the book.. keep getting " unsupported formatt? dam frustrating.. i am ready to pack it up in the box and send it back asking for my money back.
I had the same problem and I called the Bose tech Support. They helped me with this problem, What you need to do is unplug your system and let it sit for a couple of minutes and then plu it back up and it should reset the system.
Posted on Nov 15, 2008
My bose lifestyle 48 say resolutio not supported when i try to play a dvd but i have sound without a picture. how can this be fixed
Is it a copied DVD or DVD-R / RW? If if says resolution not supported then it means that the DVD has a video format that cannot be played on the Bose even though the sound track is fine. The DVD may work fine on a PC as these can usually play more file types, but it could be a number of things causing it not to work and unfortunatetly there is nothing you can do.
Jun 29, 2014 | Bose Lifestyle 48 System
Pink and green colours seem to be too vibrant when watching dvd's on lifestyle 48
I have a Lifestyle 48 which suddenly started producing a pink and green image when playing DVDs (regular TV was fine.) After speaking with Bose support, I did the following which resolved the problem:
1. Removed power from the video switcher. (or from the bose itself if you don't use the switcher.)
2. Reattach all the video cables on the back of the bose and ensure all connections to the TV and switcher (if applicable) are tight.
After performing these steps, my DVD image went back to normal. I suspect it was a loose cable in the end, but no harm in performing the power disconnect.
Apr 11, 2010 | Bose Lifestyle 35 System
I have Boss Life Style 48 system. It does not play Blue Ray - says the format is unsupported. Is this correct or we need to make some settings?
The Bose Lifestyle 48 does not contain a BluRay player. It will only play DVD's and CD's. I downloaded the specifications & owner's manual for this information.
BluRay players are a completely different format from DVD's.
Sorry, I hope this helps.
Rhais
Sep 19, 2009 | Audio Players & Recorders
DVD Format Problem in Bose LS 48
Follow this button sequence press when the error message appears"
Right Navigation - Up Navigation - Shuffle - Stop - Mute
this is make is play all discs.
Jul 27, 2009 | Bose Lifestyle 48 System
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Same problem LS 38< two years, error 802, unplug and erase umusic
Sounds like hard drive is failing, 802 and 801 is hard drive problem. i have same problem. only fixable by bose repair man... tryed to change hard drive myself, changed over, looks same as playing but no sound. hope this helps:) common problem with bose other than that i have had not other probs.
Jul 10, 2009 | Bose Lifestyle 48 System
Sound only from disc in unit
i will tell you to contact Bose I had a small problem with my bose system had to send it back they fixed it for free and extended my warrenty from day one. yop bought bose for a reason and they are a great company used there service they have always been great. I whis i knew how to help you with that I havent had any experiance with there 48 system and digital recorded data systems. but would bet that it is a problem that is more than simple. when a bose breakes it is normally major thay make really good stuff, pricey but good
Jun 27, 2009 | Bose Lifestyle 48 System
Weird gearing sound while playing CD or DVD
send it back to bose in Framingham, Ma for repair. Get loaner from where you bought system.
Nov 02, 2007 | Bose Lifestyle 48 System
Bose 3&#183;2&#183;1 II System Logo
212 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
