Question about Panasonic SD-YD250 Bread Maker
S 253 panasonic bread maker replacement bread pan
I HAVE A PANASONIC SD 253. BAKING BREAD THE TOP STAY WHITE. SIDES AND BOTTOM GETS BROWN. WHY?
This is a very nice machine. If you want bread brown on top, cover pan with aluminum foil shinny side down. I dont like brown sides an white tops either. Enjoy.
Jan 29, 2015 | Panasonic Sd253 Breadmaker Pan Kneading...
I have just been given a panasonic sd 253,but no manual,i am new to breadmakers can you help,were can i get a manual
Have you tried the Panasonic web site? They often have manuals for download. If not any bread making book should help. The only thing to remember is that Panasonic machines work best with the yeast being put in first, then the flour. Any machine recipe can be used if you remember that rule.
Sep 27, 2011 | Panasonic SD-YD250 Bread Maker
Availability of a new bread pan for a bakers oven and price?
Click here for a replacement bread pan, price is in NZ $$
Click here for a manual
This is on page 13 of the manual
Spare Par ts
Replacement parts are available from Breville
Spare Parts:
Australia Customer Service: 1300 139 798
New Zealand Customer Service: 0800 253 007
heatman101
Sep 06, 2011 | Microwave Ovens
Need a manual for panasonic sd 253 breadmaker
GOTO THE PANASONIC WEBSITE AND DOWNLOAD A COPY
Jul 04, 2011 | Panasonic SD-YD205 Bread Maker
The paddle on my panasonic breadmaker has stopped turning. Without the pan the mechanism revolves but once the pan is in place the paddle does not move.
If you take the pan out of the machine and can't turn the paddle freely by hand, then the sealed bearing is frozen. You can try putting warm water in the pan and soaking it. After a few tries if it does not free up then the sealed bearing is broken and bread pan needs to be replaced. Good Luck..Hank
Feb 06, 2010 | Panasonic SD-YD205 Bread Maker
Panasonic SD-YD205 Bread Maker: Paddle gets stuck then continues.
Take the bread pan out of the machine and run a kneading cycle. If it is noisy with the pan out then you can take the belt off and try a kneading cycle again. If it's quiet, the yep it's the belt. If still noisy its a gear or the motor itself. If everything is quiet with the pan out then it's the pan itself. There is a sealed bearing in the pan that allows the paddle to spin. The seal on the bearing leaks oil and the bearing either freezes or does not let the paddle spin freely. There is no replacement for the sealed bearing ..and a new pan is needed. Good Luck Hank
Dec 10, 2009 | Panasonic SD-YD205 Bread Maker
Where can I buy a replacement Miller's Choice Bread Maker Pan please?
The Swan fastbake bread maker is the bestBread maker that I have ever owned. Now I will let you into a sad secret I own five breadmakers at present, Panasonic,Hinari,Morphy Richards,and a Crown. The Swan comes up trumps every time.The auto nut dispenser is a nice touch.The pan makes a good size family loaf ideal for the beginner and for the more adventurous amongst us a fully individual program setting for doe mix adjust heat and mixing times. The bread comes out just as you would expect to see a loaf at the bakers but without all the rising agents and various additives that are supposed to keep yourbread fresh for `seven` days. Seven days, I have trouble keeping the bread seven minutes once the family tribe get the scent of fresh baked bread.
Jun 19, 2009 | Kitchen Appliances - Others
Panasonic SD-YD250 Bread Maker Logo
119 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
