Question about Zyxel Prestige 660H Router
Modem router my pc and laptop work off my wireless zyxel router but i have lost the password and my new laptop needs a security code?? help please?
  • Anonymous Sep 03, 2008
    decode zyxel router
    Problem Solver:
  • 6 Answers
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Posted on May 11, 2008
I need the security key for my ZyXel E72 in order to setup my new laptop for home use
  1. Look through the manual for your particular model of router. Contained within should be the IP (Internet protocol) address for your router. Input this address into your Internet browser to access your router's security settings. The address will typically be something like 192.168.1.1
  2. Enter the default user name and password for the router, which should also be in the instruction manual. If you have lost the manual, you can often obtain an electronic copy online at the manufacturer's website. Most default router passwords are something along the lines of "username: admin," "password: admin." Thus, try inputting "admin" as both the username and the password if you are having trouble locating your manual.
  3. Navigate to the "wireless security" option from the Options menu that will appear in your Internet browser. There you will find the network security code listed under the WEP settings. Write the code down and keep it in a safe place. You can change the code every month if you feel it necessary to prevent people from attaining access to your network through sheer luck and persistence. Default settings are:
  4. IP adddress: 192.168.1.1
  5. Username : admin
  6. password: 1234
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | Zyxel P660HW-D1 Router
I dont know ho to change the password on the PK5000Z Wireless Router
I just set up my new ZyXEL PK500Z, so happen to know this answer. In the ZyXEL Qwest Modem Configuration (launch 192.168.0.1), select Wireless Setup, then Wireless Security. Scroll down to Enter Security Key/Passphrase. Unless you changed this, Use Default is selected. If you want to use a password of your own creation, select Use Custom, then enter the password you want. Finish with Apply. Everything connected to your network will be prompted to re-enter the password. Is this what you were after?
Dec 25, 2010 | Zyxel (91-004-361002) Wireless Router
Hi,i just bought new laptop and my laptop want to connect to wireless. So the wireless modem is inside my housemate room and my housemate now currently stay at out country. So have anyway can i get the...
if you mean the WEP key to be able to connect to the router then there is no way of getting this Legally but if you are connected to the router already and you just want to access the control panel then enter the routers ip into your browser address bar. the default ip for this router is 192.168.1.1 the default username is 'admin' and the default password is '1234' if it has not been changed by your housemate.
Nov 25, 2009 | Zyxel Prestige 320W Wireless Firewall...
I have a Zyxel 660HW modem/router - I can't access wireless
switch it on, it will search for wireless accespoint in ur network. connect to it and given security passphrase and then ut will connect permantently.
Apr 24, 2009 | Zyxel P660HW-D1 Router
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
Feb 08, 2009 | Linksys Wireless-G WRT54G Router
How do you access WPA Key Settings on a ZyXEL modem?
To access Zyxel configuration/setup utility, launch a web browser (Internet Explorer, Opera, Firefox, or Netscape, etc.) on your computer, type in http://192.168.1.1 (default IP address for most Zyxel wireless devices) in your Internet browser's Location/Address bar, and then press Enter on your keyboard.
If presented with a user authentication (login) screen, try the following:
Default Username - Zyxel Wireless Router: N/A (none, leave blank)
Default Password - Zyxel Wireless Router : 1234
If you cannot login using the above, verify that (a) you are entering your password correctly, and that (b) your CAPSLOCK key is off. It could also be due to the firmware (a set of instructions stored on an EEPROM microchip) on your Zyxel product being corrupt. If so, you would need to reset your Zyxel WiFi router to its factory default settings.
IMPORTANT: Do not forget to promptly secure your Zyxel router (using a strong password, a non-obvious WEP Key, etc.) following a reset to factory default settings. Failing to do so may potentially expose your entire WLAN to scammers.
*Your vote is highly appreciated. Thanks in advance.
Dec 27, 2008 | Zyxel P660HW-D1 Router
Zyxel wireless router password
hi . do you guys cant access to your wireless router ? if yes than try this
reset your modem by pressing reset button on your modem for more than 5 seconds so all the information entered will be gone including your password
than insert your modem CD and connect to your modem
set up your internet again
put your password and user name that your ISP gave you
set : get IP from ISP
get DNS from ISP
APPLY
than go to wireless setting
use wpa- personal
and set up a new password eg. (usa2008)
than it will say your computers and network setting doesnt match
go to connect find your modem
right click on it
click on properties
than go security
choose WPA- personal
TKIP
and your password (usa2008) you set to your modem
connect to your internet
im not sure if this is what you mean / thats how i anderstood your problem
NOTE : RESET YOUR MODEM IF YOU HAVE ALL YOUR INTERNET SERVICE INFORMATION
BECAUSE IT WILL DELETE ALL INFORMATION IN YOUR MODEM including user name / password / IP / DNS / and your modems password
Aug 17, 2008 | Zyxel Prestige 660HW Wireless Router...
Zyxel p660hw wireless problem
I forgot my modem wireless password...and I can not make a connection without cable...
Jul 12, 2008 | Zyxel P660HW-D1 Router
TCP connection
hi i two laptop one is sony and is working perfectly with wire connecter to router n with wireless but i buyed another laptop toshiba and try router connection its working brilliant but when i try connecting wireless its keep asking me a network security key or passphrase for zyxel and under that it say the person who set up the password can give u the key or the passphrase
please help me my email is ashwaq_20002001@yahoo.com
Jun 18, 2008 | Zyxel Prestige 660HW Wireless Router...
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
Zyxel Prestige 660H Router Logo
356 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
