Question about Nespresso Aeroccino Automatic Milk Frother
Burnt Milk at Bottom of Aeroccino
There is a spot on my aeroccino where the milk keeps burning...for a while I was able to remove the burnt stuff (with some work) but now it's like the spot is permanent and nothing will remove it. Help please????!!
Try this - make a paste from bicarbonate of soda and water and let it
sit in the bottom of the frother for ten minutes or so. Then use a sponge
to clean off the milk stain and rinse and dry thoroughly. To prevent it from
recurring, rinse and dry the inside after each use and don't get the base
of the frother wet.
Posted on Dec 12, 2010
My solution: after "burning milk", empty the aeroccino and first, rinse shortly but well with running hot water. Then fill until the higher level mark with cold water, place the bigger propeller and let it working the same way you prepare milk. Wait until the water is hot. If desired, repeat more times. Burnt milk gets soft and even very old rests you can remove with a sponge very easily.
Posted on Sep 21, 2012
After each use, don\'t just rinse. If you feel the bottom there is an almost invisible layer of milk scum on the bottom. If you don\'t remove this each time, it burns the next time and leaves the brown/black residue. You can use your fingers to rub the scum off each time, but it is easier to use a bottle brush to brush the bottom with each rinse. If you get rid of the scum each time, you won\'t ever see that burned stuff again!
Posted on Jul 07, 2013
    Problem Solver:
Advice from Nespresso themselves for this issue was to run a 'deep clean' which can be done as follows:
1. Half fill the frother with cold water and a drop of washing up liquid with the whisk attachment in place.
2. Press and hold the button until it turns blue - important that you do a cold cycle - not hot - to avoid the mark getting further burnt into the frother.
3. Run twice more back to back (as soon as the cycle finishes run it again).
4. Leave the frother to stand for an hour with the solution still in place.
5. Wipe with non-abrasive cloth.
This *didn't* work for me but I think I'd burnt the milk on so many hot cycles its beyond help. If I can find the proof of purchase they will swap the Aerocinno free of charge. Great service.
Posted on Dec 04, 2014
    Problem Solver:
Spray with mr muscle oven cleaner. Leave for a few hours, then thoroughly rinse. Removes the burnt milk without scratching the Teflon finish.
Posted on Dec 21, 2014
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Aug 26, 2012 | Coffee Makers & Espresso Machines
Tip
Nespresso Frother burnt spot - how to avoid
Avoiding a burnt spot in the frotherBecause the frother impellar is magnetic, it will stick to anywhere on the bottom of the frother. It will even stick to the bottom if it is not on the little pillar that it should spin on.If you insert the impellar into the milk after it is filled, it is very easy to think you have put it in the right place (because it seems to stick to the bottom). If it is not on the pillar it will not actually do its job of spinning (it needs to do this to create the "frothing", but also it is needed to circulate the milk to prevent a "hot spot" in the milk - burning occurs if the milk is not circulated).So . . . always check the impellar is correctly fitted - or burnt milk will be a problem
on May 10, 2014 | Nespresso Aeroccino Automatic Milk Frother
Tip
Nespresso Aeroccino Automatic Milk Frother Instructional Video
Click on the link below for the user guide for the Nespresso Aeroccino Automatic Milk Frother - http://www1.nespresso.com/precom/accessories/demo/aeroccino/index.php?lang=en
on Apr 27, 2011 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino frother won't turn back on after we get some froth and still more milk in container.. takes a long time to be able to activate again.. using Almond milk could be the problem any suggeest
My Nespresso Aeroccino often would not heat or froth multiple times after one use. I called Nespresso, they have excellent customer service, and was told to rise the inside (careful not to get the outside button or electric elements wet) of the Aeroccino with cold water a few times and to retry. Works like a charm!
The customer service is the best I have encountered in a long while, give them a call, it will make your day they are so pleasant and helpful!
Feb 18, 2012 | Nespresso Aeroccino Automatic Milk Frother
My Aeroccino keeps overflowing even though the level of my milk is below the min level.
I am having the same problem but not every time. I went back to where I bought it and spoke with one of the reps and was told that if there is moisture under the rubber seal on the lid this will happen. To solve this I remove the rubber seal and clean it and dry it off after I am done using it. Also turn the lid over on top when not in use. Hope this helps.
Mar 01, 2010 | Nespresso Aeroccino Automatic Milk Frother
Doesn't heat completely and light blinks
This is either a problem with the thermostat that lives just under the surface of the bottom of the aeroccino jug and is a technical problem that can only be resolved (replaced) by returning it to Nespresso OR it is related to a fine layer of burnt milk that builds over successive use that builds and holds the heat the element produces 'tricking' the thermostat into thinking the milk itself has heated to the desired temperature, not just the burnt layer. Clean the bottom of the jug, regularly with a non scratch scourer and use a mild detergent as well.
Jan 23, 2010 | Nespresso Aeroccino Automatic Milk Frother
My nespresso aeroccino machine seems either quirky or moody: sometimes it froths the milk, and other times it just kind of heats it up and stirs it, even though I'm pouring the right amount of milk in and...
THEY SAY MILK MATTERS. SKIM OR LOW FAT BEST. ALSO MAKE SURE IT IS CLEAN, WHEN YOU ARE CLEANING IT, REMOVE THE FROTHER, TO BE SURE MILK DOES NOT STUCK IM COIL, WHICH CAN MAKE THE FROTHER, NOT MOVE AS QUICKLY AROUND.
Jan 19, 2010 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino milk scum hard to remove
I have used a baby bottle brush. It is not easy to clean, and the cooked milk does build up, and the scum build up will cause the frother not to move as fast compared to when it is clean.
Jun 10, 2009 | Nespresso Aeroccino Automatic Milk Frother
Nespresso aeroccino
It would seem that I was not putting sufficient milk into the aeroccino. I amm putting more in now and monitoring the situation. So far ,so good!
Oct 02, 2008 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino Automatic Milk Frother Logo
23,385 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
