I had to resset my password on HP Compaq 6910p. It seems it didn't accept the password change and now the laptop won't start- it freezes at the windows xp screeen. I have done a hard shut down several times and considered looked at restart in safe mode etc but can't afford to wipe out al data files as not backed up.
  • 304 Answers
You may reset the Windows Login password without losing any Data by using the Application "Ophrack".
You will find the detailed instructions to use this Application in the link below:
http://pcsupport.about.com/od/toolsofthetrade/ss/ophcracksbs.htm
You may download the Ophcrack Application from the below link:
http://ophcrack.sourceforge.net/
Hope this helps:
Posted on Jul 10, 2010
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Where dos jumper located on compaq 6910p and how can i remove bios password on 6910p
Most "laptop" computer do *NOT* have a jumper that can be used to bypass a BIOS password.
This is DELIBERATELY done, so that a thief in possession of your laptop cannot bypass your password, and thus cannot use your stolen laptop.
Find your original bill-of-sale, to prove ownership, and telephone HP/Compaq, and ask for Technical Supoprt in resetting the BIOS password.
Jun 20, 2011 | SIB SATA 250GB for HP/Compaq 6910P NW8440...
I Need Help Unlocking My Hp Compaq 6910p Every Time I Turn It On A Blue Screen Pop Up And It Say POWER ON PASSWORD .... PLEASE ANYONE HELP ME UNLOCK MY LAPTOP!!!!
Unfortunately HP says: "If you forget the power-on password, the computer must be reset at an HP-certified repair center. Please contact HP to schedule a repair. The Drive Lock password cannot be reset. If you lose or forget the Drive Lock password, the hard drive must be replaced. Please contact HP to order a new hard drive. These services are not covered by the warranty."
Sep 13, 2010 | HP Compaq 6910p Notebook PC PC Notebook
I have a laptop hp Compaq 6910p, and by mistake I ...
Its too risky for a user to open the laptop, access the mainboard and reset to its factory setting..
Very dangerous for the hardware too..
My suggestion is to bring your laptop to a credible technician to open your laptop, reset the cmos to its factory, and return the cover properly..
Hope you understand.
Much appreciated if you rate this help.. thanks
May 20, 2010 | HP Business Notebook 6910p Notebook
Is buying this Hp Compaq 6910p Battery a wise decision?
I have bought a couple of batteries from them before. They work just make sure that the voltage of the battery. (10.8v) matches the voltage on your battery. Also make sure that the mah 6600mah is greater or the same as the battery that you have. The mah is the mili ampers per hour (in other words the fuel) the bigger the mah the longer your battery will run. I also find ebay a great place to buy hp batterys from. Just make sure that they are oem hp and not a generic knock off and you will be fine and use the same rules from above. and also make sure they will fit your model number. I hope this helps
thanks
Steven.
Apr 24, 2010 | HP Pavilion dv6000z Notebook
I have an hp compaq 6910p lap top which a friend has password it in the setup and i am finding it difficult to use it. what should i do to clear the password in the setup. eric
You can try to open your computer and disconnect the cmos battery for 10 minutes. this is a small battery that keep the changes saved. When you disconnect it, All changes will be lost. So also the password. This is the sequence:
1: take off the accu
2: open up the laptop
3: take the cmos (small flat round battery) out
4: Wait 10 minutes
5: plug in you adapter and boot the laptop
6: when you see that the password is gone, power off the laptop
7: plug everything back in.
8: You are done! :)
Apr 20, 2010 | HP Configurable- HP Compaq 6910p Notebook...
Not getting sound
check your sound drivers,and the sound mixer
Apr 02, 2010 | HP Compaq 6910p Notebook PC PC Notebook
When typing on my HP notebook (Compaq 6910p) I find the cursor jumping from place to place as I type.........Help. Doesn't seem to be any pattern to the issue.
The sensitivity of the touchpad maybe too high, this is a common problem and can be easily sorted.
Go into the control panel and select mouse, there you can set the sensitivity of the pad.
See if that helps any!!!
Good luck.
Jul 01, 2009 | HP Compaq Business Notebook 6910p
Computers & Internet Logo
79 people viewed this question
Alun Cox
David Payne
David Payne
