Question about Quinny Buzz Three Wheel Stroller
How to take off the Quinny front wheel for easy travelling?
I pressed the two side buttons, but the wheel does not come out. I want to know how? Thanks!
    Problem Solver:
  • 5 Answers
They can be quite difficult to get off, I found that I had to use two screwdrivers to press the buttons in and forward slightly to release them from the holes as they are quite strongly spring loaded, once they clear the main tube and disappear inside the wheel unit will be released.
Posted on Jul 17, 2010
Change the position from recline
Hi Claire
Stand in front of the Buzz chassis at the front wheel. On either side of the seat unit you have a grey button. Push the button down and now you recline the seat / sit it upright as required.
http://www.quinny.com/-/media/Quinny/Product%20content/Manuals%20and%20instructions/buzz/MAN_DRU1074A14_Q_BUZZ_V1_2014_ENFRDENLESITPTKOPLELRUCS.pdf
Jan 16, 2014 | Quinny Buzz Three Wheel Stroller
Remove the quinny seat from the base, then collapse the base
Good Afternoon
On either side of the Buzz seat there is two catches; you use these catches to recline the seat unit to the required angle. Push them both down and it unlocks the seat - Lift the seat toward you and it will come off the chassis.
To collapse the unit down, its easiest to do so when you're standing in front of it. On the left side knuckle is a button you need to push down: On the right side is another button with arrows on it which you need to push and bring toward you. With your hands on these buttons bring the weight of the Buzz toward you and angle toward the floor, and it will slide into the collapsed position. Ensure the transport lock is on before travelling with it collapsed.
May 27, 2011 | Quinny Buzz Three Wheel Stroller
I am un able to change the position of the seat, I have pressed the greyt buttons on the side but it is solid in one position
Good Evening
Please contact your retailer with your proof of purchase or alternatively go to www.quinny.com and select your country and use the "Contact Us" tab to connect with Quinny customer service department in your country.
May 07, 2011 | Quinny Buzz 3 Travel System Phantom...
How do you fold a quinny buzz?the instructions dont help!
position the pram so the front wheel is facing you,put your feet either side of the wheel to stop the wheels moving
push the two grey button that are on either side and as you push the buttons pull down the frame towards you.
hope this helps.
Mar 07, 2010 | Quinny Buzz Jogger
How do you fold down the quinny zapp
the steps are numbered 123 on the stroller. press the big round button numbered 1 on the right side (i think), which is located where the handle meets the main part of the stroller. Press the big round button numbered 2 on the other side. After you press button 2, you should be able to fold the handles (both of them together) forward, swinging the handlebars out in an arc until they're nearly touching the front wheel, on the ground. Now, step 3 is the difficult one--you've got to release the catch numbered 3 (underneath the seat, directly beneath where the baby's bottom goes) and then slide the ring forward, along the rod underneath the seat, toward the front wheel. If you can get it going, the rest will happen very smoothly, and the stroller will fold very compactly. It's difficult to describe, but once you get it, it's a cinch after a little practice. Good luck!
Dec 10, 2008 | Quinny ZAPP Stroller
My quinny buzz front wheel keeps getting stuck half way and i end up trying to push the chair with the front wheel sideways which is impossible. i have been advised to clean the front wheel out as it gets...
First remove the front wheel assembly from the pushchair by pressing in the two buttons on the sides and pulling it out.
Now look more closely at the assembly - on one side, just where it bends at an angle you will find a small hole, a couple of millimetres across. Take a small screwdriver or some other thin object and push it into the hole a little way, which presses a metal catch inwards, releasing the swivel assembly. While continuing to push this in pull the swivel assembly apart - grasp the wheels in one hand and the L-shaped plastic housing in the other and pull them apart.
Now clean all the surfaces with a piece of strong cloth.
When all the surfaces are very clean, take a can of TEFLON SPRAY and spray it onto all surfaces that rub against each other, before reassembling the wheel unit. Silicon grease is a cheaper alternative, but the teflon spray is supposed to be the best for lubricating all moving parts on the Buzz. Whatever you do, don't use WD40.
Hope this helps! Dan.
Nov 11, 2008 | Quinny Buzz Jogger
Funny front wheels
remove the total front housing by pressing the 2 plastic buttons on the silver bar that holds the wheels in place. then get a small screwdriver and put in in the small hole on the black plastic part of the wheel there is a button in there but you will need to look in the hole to find it then push button with screwdriver and pull off the 2 wheels. clean and use wd40 not oil. this should fix problem if not phone dorel (they sell/own quinny) in the UK 00442082360707
May 10, 2008 | Quinny Buzz Jogger
Quinny buzz
Tyres-press the light grey button on the chassis next to the wheel slot as you push on the wheel (this is also the button you press to release each wheel).
Opening it is easy - With Buzzwheels on the ground, remove safety hook (plastic loop on left side of handle fixed to peg inner left rear wheel) ten simple lift handle and Buzz frame should automatically pop up.
Closing takes more practice-put on brakes (press red foot pedal) stand to side of chassis and at bottom end of handle there are two large grey buttons. With left hand on left button push button forwards (ie direction of chevrons on button) then press in. At the same time push in right button with right hand. Whilst doing this you also need to push down and forad on frame and it should fold down. If you don't push buttons enough it can click. When folded remember to put on safety hook before transit, otherwise it might pop up on its own. Hope this helps. You can download the manual with instructions from Quinny website too if pictures are helpful!
Apr 25, 2008 | Quinny Buzz Jogger
How do you close quinny buzz
you need to stand at the front of the pushchair, push in the left grey button and then push the right one down and towards you all at the same time!! whilst doing this push the frame down towards the front wheel! when i first got mine had real problems figuring it out once you do its easy!! remember to hook on the safety catch though cause one touch of the handle and it pops open. i did read that in cold weather it can be a little stiff. not sure on the car seat though as didnt have one! sorry
Mar 08, 2008 | Quinny Buzz Jogger
Quinny Buzz Three Wheel Stroller Logo
75 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
