Question about Electrical Supplies
Hi i have a 4cyl diesel generator it starts and stops if i bypass the shut off soilinoid it runs anf funtions fine i repaced the ols soilinoid with a new one but it still shuts it down any thoughts??
    Scholar:
  • 142 Answers
The Stop solenoid is OK. You should check the protection oil level or oil pressure sensor, or the respective level or pressure.
Posted on Jul 10, 2010
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
My diesel kipor 5kva generator wont shut by key ,
Caution
the manufacture is recommending a cool down period of about 3 minutes to prevent overheating of the combustion chamber. the following is from the manufacture on shut down procedure.
3.2.8Check Stopping of Generating Set
(1)Disconnect the load from the generating set.
(2)Turn off the air switch of the generating set.
(3)Set the speed lever at RUN position, run the generating set without load for about 3 minutes. Do not stop the engine suddenly, otherwise the temperature will increase abnormally, the nozzle will blocked and the generating set will be damaged.
Press down the stop lever. Concerning the electric starter, turn the key to OFF. Turn the fuel **** lever to S position.
Pull out the recoil starter handle until you feel resistance (at this position, both intake/exhaust valve are closed.) and leave the handle in this position. This prevents the engine from rust.
If the engine keep on running even after the speed lever is placed at the STOP position, either turn the fuel **** to the CLOSE position or loosen the nut of high pressure fuel pipe on the pump side to stop the engine.
Do not stop the engine with the decompression lever.
Do not stop the generating set with load. Stop it after the load removed.
the following link provides the complete maintenance manual for the diesel generator
http://www.rcremers.nl/webshop/handleidingen?download=20:handleiding-aggregaat
Jan 12, 2016 | Kipor Electrical Supplies
Hi. After the weekly test, the generator wont shut off
What kind of generator, what is the start/run system? If it's diesel, the cutoff solenoid wire has probably come disconnected, if it's gasoline, the magneto grounding wire has probably come loose.
Oct 20, 2014 | Electrical Supplies
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Jul 21, 2014 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
Engine Diesels
Hi! May I suggest de-coke? I know in modern times fuels are refined better but you may be running a little too rich on one or more cylinders so flecks of soot remain glowing causing run on detonation. Maybe a fuel additive or neat RedeX?
Hope this helps?
Paul 'W'
Onyer~Edson(:0~[><
Dec 04, 2008 | 1989 Jeep Wrangler
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
