Question about SanDisk Sansa e200 MP3 Player
My sans e200 is not refreshing
Once yyyou swithc on,the refreshbar moves to some length and finally stops
  • Anonymous May 05, 2008
    Sansa turns on, then starts to refresh, but stops and stays in the same spot. Also, when I plug my sansa into the computer, the screen doesn't say "Connected" like it should. It instead boots up as if I were turning it on to listen to music and not plug into the computer.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
My sansa e250 keeps shutting down
switch the usb mode which ever one is highlighted first chose the other and then it will stop refreshing
Feb 19, 2009 | SanDisk Sansa e200 MP3 Player
Showing refresh database
try to format the player once..now download the songs and give it a try... :)
Sep 15, 2008 | SanDisk Sansa e200 MP3 Player
Help i can't open my sansa E200
Go to the place where you bought your Sansa E200 and ask them to have the firmware reinstalled. Most mp3/mp4 players crashes its firmware when you are working on something and the battery goes down. There is nothing wrong with your gadget's harware, just a software issue.. that's all.
A Simple Thank You is Good enough
Feb 15, 2008 | SanDisk Sansa e200 MP3 Player
Help
But after refreshing does it become normal....? If it becomes normal, then the grayish is normal.
Refresh database
Sansa e200 provides a RESET function for unresponsive units. Press and hold the MENU button for 15 seconds, and this should work to regain normal funtionality. Please note: settings and adjustments from the last operation WILL BE LOST. The files however should remain.
Sep 19, 2007 | SanDisk Sansa e200 MP3 Player
My sansa e270 freezes 3/4 of the way thru the refresh database screen Does anyone have any suggestions?
hello sorry for disturbing alot and i have a really problem with my sansa e200 mp3 and really have big prouble with that and can evern refresh the databaes and i need help to find that back with me now and i m mr.collins anderson and my yahoo address is colins_bills2000@yahoo.com
Aug 13, 2007 | SanDisk Sansa e200 MP3 Player
Sansa mp3 player freezes at refresh database
The Same thing happened to Me once. All you have to do is reformat it. You can do this by first putting the player in recovery mode. You can do this by putting the hold button on the side where you can see the orange and then plug the device into the computer while holding the power/Menu button. Then go to my computer to Verify that it came up as 16MB-Format. Then you can type into the address bar and type in http://mp3support.sandisk.com/firmware/rhapsody-1.0.2.165.zip. then once you do that right click on the file you downloaded and select open with compressed folder and drop and drag to the 16MB-Format drive. In the 16MB-Format drive folder select file menu and select New - Folder and rename it sansa.fmt then press enter to save. Finally move the hold switch back and disconnect the device and look at the screen and verify it is formatting and resetting once it's done and finishes the updates restart and if needed pick your language. check and see if you can use your player.
Mar 26, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
