Canon pixma mp450 driver - Office Equipment & Supplies
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    do you need a driver for your printer? If so, what is your operating system please?
I NEED TO INSTAL THE DRIVER CANON DRIVER PIXMA MP450
Posted on Jan 31, 2009
SOURCE: Canon PIXMA MP450
carraige error
Posted on Mar 28, 2007
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Posted on Dec 06, 2007
  • 37 Answers
An Error Message Is Displayed On The LCD title-bar.gif If an error message is displayed on the LCD, take the corresponding countermeasure described below.
Message
Action
There are no photos in memory card.
There are only invalid images on the memory card.
Photo data edited/processed on a computer should be printed from the computer, not from the camera.
There is no paper.
Reload the paper correctly and press [OK].
The paper is jammed.
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [OK].
Ink has run out.
U041
Replace the FINE Cartridge, and close the Scanning Unit.
If printing is not finished yet, just press [OK] on the machine to continue printing in the "no ink" state.
Replace the FINE Cartridge with a new one as soon as possible after printing finishes. The machine may be damaged if printing is continued under the ink out condition.
The following ink cartridge cannot be recognized.
U051
U052
U053
U059
The FINE Cartridge may not be installed properly, or the Cartridge may not be the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Some ink cartridges are not installed in place.
U075
U076
Confirm that the FINE Cartridges are installed in the appropriate positions.
The ink absorber is almost full. Press [OK] to continue printing. Contact the service center.
The ink absorber is almost full. Printing will no longer be possible once the ink absorber is full. Contact the service center immediately. Press [OK] to continue printing.
Incompatible device detected.
Depending on the model or brand of your device, you may have to select a print mode compliant with PictBridge before connecting the device.
You may also have to turn ON the device or select Play mode manually after connecting the device to the machine. Perform the necessary operations according to the instruction manual supplied with your device.
If the error is still unresolved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this machine. Use a digital cameras or digital video camcorder compatible with this machine.
Auto head align has failed.
Make sure all required boxes on the head alignment sheet are filled in, and that the sheet is set in the correct position and orientation on the Platen Glass.
If the machine is connected to the computer, you can align the FINE Cartridge using the MP Driver. Follow the procedures described in the Printer Driver Guide.
The following ink may have run out.
U162
This FINE Cartridge may have previously been used, or the ink may have run out. The function for detecting the remaining ink level will be disabled since the remaining ink level cannot be correctly detected. If you want to continue printing without this function, press [OK]. Canon recommends to use new genuine Canon Cartridges in order to obtain optimum qualities.
U140
The FINE Cartridge may not be the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Printer error.
An error requiring servicing might have occurred. Turn OFF the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn ON the machine. If the same error occurs, contact a Canon service representative.
Posted on Jun 08, 2008
pineworks
  • 4041 Answers
SOURCE: How to Clean the Canon Pixma MP450 Printer Waste
How To Reset Waste Ink Canon Pixma MP450
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
pineworks
  • 4041 Answers
SOURCE: Canon Pixma MP450 - I am getting error code 5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Posted on Feb 25, 2010
Testimonial: "Had it figured out that it was the purge cap (once the cartridge stopped there it wouldn't print) but didn't know how to fix it -thanks for your help!"
I have a pixma mp450 all in one printer the disc that came with it is messed up where do i get drivers.
You can download the Canon drivers from these WEB sites, make sure you select you model printer and the Windows version on the driver.
Canon drivers download
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Printer Drivers - XP to Windows 7
www.Paretologic.com/Drivers_printer
Jan 27, 2010 | Canon Pixma MP450 All-In-One InkJet...
Canon pixma mp450
your posting this for the 3rd time?
download drivers from
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=11865
click on drivers and downloads, the drivers are there, if they don't show up instantly, try again. they are there on that page.
Let me know if you need anythin else.
Thanks,
Ekse
Mar 07, 2009 | Canon Office Equipment & Supplies
Canon pixma MP450
Go to the official Canon website: www.usa.canon.com and download your driver. The download is free.
Jan 26, 2009 | Canon Pixma MP450 All-In-One InkJet...
I lost my installation disk
Use this link if your operating system is WinXP or Win2000:
http://drivers.softpedia.com/get/PRINTER/CANON/Canon-PIXMA-MP450-MP-Drivers-2kxp-101.shtml
for other Operating system pease leave a note.
Cheers!
Apr 12, 2008 | Canon Pixma MP450 All-In-One InkJet...
367 people viewed this question
jasbo
jasbo
