Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I have a Dream Maker x-spa Dition 4 person spa. i
I have a Dream Maker x-spa Dition 4 person spa. i went to use it last night and it was not working and it displayed (sn) on the window. I tried unplugging the spa and waiting and plugging it back in. This had no effect. Please help with any ideas. thanks
Hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe joeathome2009@hotmail.com
Posted on Aug 06, 2010
Dream Maker Spa lights BLINKING
possible bad heater element or temp sensor or recirculation pump
Mar 06, 2013 | Dream Maker Spas Pool & Spa
Dream Maker x-500 5 person developed cracks in the shell of the 2 corner seats, nearest the access panel. It appears the seat supports molded to the base of the spa are pushing the seat bottoms upwards,...
If it's loosing water this should be a structure warranty. I have two of these and had to drain the spa and shine a light in the spa and take pictures from underneath. Then the light will show off the cracks well. If your the original owner just keep at Dream maker, they should give you a new one.
Dec 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hello, I own a Dream Maker Eclipse 4-person Portable Spa. We have it on the porch, and we have noticed a leakage apparently between the pump and the filter. Do you have any suggestions how to fix the...
The Dream Maker Company (Dream Maker Spas, LLC) will be your best bet at finding a local service center in your area.
Email Customer Service @ lisav@dreammakerspas.com. You will normally receive a response in 24 hours. Be detailed about your location (City, State, Zip) and try to provide as much detail about your spa as possible.
Dec 08, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker spa - does my dream maker spa 4 person have a thermostat or temperature sensor that can be changed out? Or, is this all in the topside control panel or CGA control box? I'm having issue's with...
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Feb 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Hot tub - Display is blank - no #'s - flashes 4 times
Hard to say without being there. Two things to check though. First be sure the new board is the correct one. Many times parts will change and replacements will have special instructions for retrofitting.
The other thing to check is be very sure the plug on the new board lines up with the receptor. On a multi pin plug if the pins don't line up you can get just the problem you describe. I hope this helps, sorry it can't be more.
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
825 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
