Question about ASUS Eee PC 900 Notebook
Notebook won't turn on
I have a an asus notebook.... it doesn't turn on even if i hold the power botton for a long time... all of it's lights doesn't turn on also whether it'd be the power, charging, or wireless light. please help me with this...
  • Tony Rose
    Tony Rose Jul 10, 2010
    Hi, sorry I didn't get all of your question, please send again, also do you have the mains adapter on when this happens?
    President:
  • 2,571 Answers
If no lights come on then its dead.
Check that the batery is fitted correctly, check that your mains lead is working ok.
It should have a light on it to show power is getting though.
If the mains adapter is working the it sounds like your laptop has shorted out, this will need taking into a shop to fix.
Posted on Jul 10, 2010
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My ASUS t500ia will not turn on anymore. Even when plugged in. The charge light is green
Hold the power button down for 30 seconds or more. Sometimes with my asus laptop i have to do this 2 or 3 times to get it to power on.
Feb 23, 2015 | ASUS Transformer Book Flip TP500L-UB51T...
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
My asus x59gl screen won't switch on, I can hear
Try holding in the function key (very bottom left key labeled Fn) and pressing F7. If that doesn't turn the screen back on, hold it again and slowly press F8 a few times. That should turn the screen back on if it was accidentally set to a different monitor, which seems to happen randomly on laptops.
If you can see a very faint image when its held at just the right angle, then you probably burned out the back-light.
Keep in mind, if you bought it in the last year, it is still under manufacturer warranty.
Feb 19, 2012 | ASUS Computers & Internet
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
My keyboard won't light up on an ASIA G73J. I have tried the function keys and they won't work.
Did you hold down the [fn] key, in combination with the function keys? If not, you have to hold down the [fn] key in combination with pressing the function key's that are associated with the keyboard back-lighting (usually [F3] or [F4] on an ASUS G-series).
Aug 03, 2011 | ASUS G73JHA1 Notebook
Toshiba satellite laptop won't wake up from hibernation even after holding power botton down?!
If pressing down and holding the restart/start button doesn't wake it up you might try Control + ALT + DELETE keys (together) - that will reboot it though. And if that won't work then you might have to pull the battery to reset it.
It seems that some laptops have a problem with vista and sleep mode, in particular, and sometimes hibernate too. You can try going under POWER OPTIONS under Control Panel and setting everything back to default, saving it, then resetting it again. Also it's best to avoid using sleep mode if possible to avoid problems.
If the problem developed after a recent install or updating you may need to go to an older store point to fix the problem. Personally, I just avoid using these settings as much as possible and use regular shut down and a screen saver for times when I need to step away from laptop for short periods of time.
Apr 27, 2011 | Toshiba Satellite Pro L300 Notebook
My ASUS Notebook webcam shows the picture botton-up...
If you are using Yahoo Messenger or Windows Live Messenger or Skype navigate to your webcam 'Settings'
Maybe in 'Advanced' look for 'Mirror Vertical' and make the change
Oct 08, 2009 | Creative Labs WebCam Live!
ASUS Eee PC 900 Notebook Logo
373 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
