Question about Hunter 52" Ceiling Fan With Light And Remote Control
Bypass Hunter 6-wire receiver
I want to bypass the remote receiver and switch to wall control. I need the schematic for the internal 6-fan/light wires that go to the receiver. The fan is a Hunter French Quarter M# 21412.I am connecting to a 4-wire run to a wall switch that has 2 sliders and a polarity flipping switch to provide fan reverse.
  • 5 Answers
SOURCE: hunter fan/light control wiring
solution depends on how many wires are in the ceiling box. was there a ceiling fan in place before? were the light and fan controlled by seperate switches or was there only one switch? if two switches, then there should be two seperate hot wires in the ceiling box. if only one switch, then only one hot wire in box. if only one, then your black and red from the fan will wire together to the single hot. green goes to the bare copper wire, if not one, then not needed
Posted on Aug 14, 2008
SOURCE: Hunter ceiling fan(French Quarter model) remote
The fan receiver is receiving signals of the proper frequency from sources other than your remote. This is very common. Could even be your neighbors remote...if you have neighbors...
If it's a real problem for you, you could try changing the frequency on your units (see owner's manual) -- that might help, or it might make it worse.
Posted on May 28, 2009
  • 34 Answers
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 10, 2009
jyackle5
  • 8197 Answers
SOURCE: Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Posted on Jan 02, 2010
SOURCE: Hunter Ceiling Fan 25885 remote won't turn off light
I have this fan model. The RED is a common wire. Wire it in with all the white wires. Better yet why don't you just bypass the module for the light. You could buy a more up to date Lutron wall switch W/remote control. The Black wire W/White stripe coming from the module is the light control. Cut & cap this with a wire nut. The same wire coming from the fan motor Connect it to your new wall switch. Now heres the tricky part. You have to run a new (Non switched) hot wire to your fan this will connect to the module normally. This is the new power for the fan. The remote that comes with the fan can serve as the On/Off 1,2 & 3 speeds. You now have two remotes. One for the fan the original and one for the light control w/wall switch. The new Lutron model will give you full dimming capability for incondesent bulbs. It is much less noisy when you are dimming the light down.
Posted on Jun 13, 2010
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
You might be able too but you need two hot wires in the house wiring. If you have two hot wires(1 for fan & 1 for light) try a fan/light wall control.
Jan 31, 2014 | Dryers
Hunter fan remote bypass
This fan uses a "ballast" to run the fan. The ballast (part #272) probably contains wiring for multiple speeds. Here is a manual that discusses the wiring- http://www.hunterfan.com/SupportDocuments/OwnersManuals/42700.pdf.
To use a wall mounted fan dimmer, you need to identify the high speed wires and connect them to the dimmer switch. This method will bypass the other speed windings and is not as power efficient.
Jan 31, 2014 | Hunter 21617 Palermo Brushed Nickel...
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Remote will not operate fan or light. Replaced battery. Remote light glows red when pressed
Check dip switches in remote and dip switches on receiver in the canopy of the fan, make sure the settings match exactly. Make sure there is power to the fan. Make sure the fan and light are not manually set to off by pullchains that may be on the fan. If the fan does have pullchains, wire it directly in (bypass the remote in the canopy) and test the functions to make sure the fan and light are working. If it works without the remote, but not with the remote, and the dip switches are set the same and you have new batteries, then the remote and receiver should be replaced.
Feb 28, 2011 | Hunter 52" Ceiling Fan With Light And...
Light s blinking on and off
Receiver for remote control of light goes bad over time. If you are competent with electrical wiring you can bypass this defective component. Take the light kit off (3 screws) and unplug the modular plug. Trace wires from lights back to a small box in the light kit containing electronic components (you can see circuit board, capacitors etc - in my case this was part # 98480-02). This is what you will be bypassing or replacing. In my case the fan did not come with a remote, so I removed & bypassed this box. (white wire to white, red wire to black. Light now works fine, no blinking.
Feb 10, 2010 | Hunter Dryers
The light is not working. Pulled the base off and
I would say the extra wires are for a receiver which must be in there somewhere.
To bypass the receiver, look for black, blue & white wires. Black is fan, blue is light fixture -- white is neutral.
The source wires (from the electric panel) would be black and white and bare copper (ground).
From here, you need to tell me what switching configuration you want: one wall switch, two wall switches, one wall switch w/ two pull chains, etc.
Charlie
Aug 17, 2009 | Hunter 20765 Stratford II Fan
Jul 24, 2009 | Hunter 28486 Ceiling Fan
Can't control light at switch
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
Jul 01, 2009 | Hunter 27185 Remote Control
Dryers Logo
635 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
