Question about Danby DPAC8020 Air Conditioner
I'm getting a P2 error when I turn my LG Air conditioner to either cool or auto. I empty'd the water tray and it continues to have this issue. Not sure what else to do.
  • 7 Answers
There is a plug in the bottom of the unit its a condensation tray that needs emptying as well not just the lift out tray happy to help
Posted on Dec 11, 2010
Why is my 8000 btu portable air conditioner leaking water all over the floor
IF this is a regular unit and not one that you add water too (like a swap cooler) it is normal for water to be produced. When those units cool the air, the water in the air condenses in the coils and drips down to a pan in the bottom. There should be a light that comes on and tells you to empty it and there should be a plug for emptying the unit. If it is leaking then the there could be issues with the tray and where the water is going.
Jun 09, 2017 | Heating & Cooling
Code p2 shows on the lcd screen after shutting down. what's wrong?
If its an LG Portable air con, P2 means that the water tank is full and needs emptying.
May 26, 2015 | Heating & Cooling
Why does my PAC unit continuously flash PF at random and simultaneous intervals?
Wild guess this is a portable air machine? with a tube out a window? Wild guess, there's a condensate "leak" where it shouldn't be. The tank drain might be blocked for some reason. or level of the machine or coils are dirty in spite of the filter.
Dec 22, 2014 | Filter Heating & Cooling
How do I drain the water from my LG portable air conditioner (LP1010SNR)
Lift up the window securing the AC, and CAREFULLY tilt back the unit. The water lays towards the back of the A/C under the fan.
Apr 17, 2012 | LG Heating & Cooling
I have a P2 error on my LG air conditioner. How do i drain the water out. TY
I think what you're seeing is actually a E2 error code. Which is "Sensor protection, to avoid occurrence of unit damage, auto-stop protection." In simple terms, one of the senors in the unit is failing or has failed and it has shut the unit OFF. If it was warning you that the bucket was full, it would show FL.
To find out more about the Sensor Protection, call LG Customer Support (800) 243-0000.
Jul 08, 2011 | LG LP0711WNR Portable Air Conditioner
LG LP0910WNR portable Air Conditioner error code P2 and shut down
P2 is a water tray full error. I had error once, and it had me puzzled because I have a tube from the back, and unit elevated. It was producing water out the back, so it was clearly draining.
Called LG (very prompt service, no wait times at all).
The girl said that error was water tray, I still didn't believe her.
So I pulled unit from location, and tipped at a good angle.
Sure enough, less that a cup of water drained, and now it works fine.
Jul 07, 2011 | Heating & Cooling
What is the P2 code on an everstar mpk 10cr1
<b>Unit Displays P1</b><br /> P1 error indicates that:<br /> <ol type="A"> <li>The water tank on the side of the unit is full. <li>The water tank in not properly seated in the housing. <li>The switch at the back of the water tank housing is not engaged or is loose </li></ol> <br /> <i>Solution</i>:<br /> <ol type="A"> <li>Empty the water tank. <li>Make sure the water tank is properly secured in the housing <li>Remove the water tank for the housing and gently tilt the switch at the upper left hand corner of the housing towards you. This should allow the tab on the water tank cover to engage the switch. </li></ol> <br /> <b>Unit Displays P2</b><br /> P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <i>Solution</i>:<br />Move the unit to a location that is suitable for draining water from the unit.<br />Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)<br /> <hr color="#cccccc" size="1" /> <b>Unit Does Not Cool/The Green Light is not on. </b><br /> Is the unit in the Cooling mode?<br /> <i>Solution</i>:<br />Press the mode button until cooling mode is selected. <br />Lower the temperature setting on the unit to the minimum setting. <br />(The temperature setting of the unit has to be lower that that of the room)<br />Wait 3 to five minutes for the compressor to start running.
Jul 06, 2010 | Danby DPAC8020 Air Conditioner
Error messages
Full of water in lower tray. Normally it takes care of moister but in extreme humidity it may be necessary to manually empty the unit.
Aug 07, 2007 | Windchaser PACR10 Portable Air Conditioner
Danby DPAC8020 Air Conditioner Logo
2,398 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
