Identifying available connections
The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV
After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers
For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
Press the Windows Key.
Type Adjust screen resolution and press Enter.
Find Display and click the down arrow on the right-hand side of the box.
Laptop Computers
If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs
Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
1)Plug in either the vga or dvi into both the projector and the laptop.
2)Plug in the power cord to the projector,then turn the projector on.
3)Once it has past its warm-up period,find the function key on your laptop.(Fn)
4)Along the F1,F2,F3 ect keys,press find the one with the picture of the display.
5)When you have found it,hold down Fn and press the display key down until it clones the laptop and projector.
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
1)Plug in either the vga or dvi into both the projector and the laptop. 2)Plug in the power cord to the projector,then turn the projector on. 3)Once it has past its warm-up period,find the function key on your laptop.(Fn) 4)Along the F1,F2,F3 ect keys,press find the one with the picture of the display. 5)When you have found it,hold down Fn and press the display key down until it clones the laptop and projector.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound. 2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows: 1. USB Connector (Connect to PC for Remote Mouse function) 2. RS-232 Connector 3. Audio Input Connector 4. S-Video Input Connector 5. DVI-I Input Connector (PC Digital (HDCP)/PC Analog/Component Video Input) 6. VGA In/SCART Connector (PC Analog Signal/Component Video Input, HDTV/SCART Input) 7. VGA Output Connector (Monitor Loop-through Output) 8. Power Socket 9. KensingtonTM Lock Port Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord 2 VGA Cable 3 DVI-I to VGA Cable (Optional accessories) 4 Audio Input Cable (Optional accessories) 5 RS232 Cable (Optional accessories) 6 USB Cable (Optional accessories
Yes this television does support 720p and 1080i. Hear is something that might solve your problem or at least get you going in the right direction.
Problems with DVI-HDTV Connection
• Make sure the DVI device is turned on and the cables are firmly connected. If problems still occur, turn off your device. Re-connect
your device. Reset the power by unplugging the power cord and plugging it back in.
• If you are tuned to the DVI-HDTV input and you’re receiving Unusable Signal message on-screen, contact the manufacturer of the
DVI device for further assistance.
• If you tune to the DVI-HDTV input and you see snow, the video goes in and out, or the video takes a long time to appear, your DVI
device is having trouble sending video information to the TV. Re-connect your device. Reset the power by unplugging the power
cord and plugging it back in. If problems persist, try connecting to the Y Pb Pr jacks instead if they are available or contact the
manufacturer of the DVI device for further assistance.
• If you have bars on each side of your picture, the device you connected might have a switch or a menu option allowing you to
change the picture format output that will fix this. Choose either 720p or 1080i.
That projector supports M1-D also which is the digital side of the M1-DA... Anyway, they sell cables that are M1-D to HDMI to which you can hook directly to the PS3. They are decently priced too, less than $20. I know this thread is old, but I came across it due to an issue I am having with my xb31, broken color wheel. Trying to find parts...
