Question about Garden
My mower motor would rev down while operating. This persisted until it got worse and now will not start. Any ideas?
  • 1,940 Answers
If there is grass or other debris build up in the engine cylinder fins, or any damage to the fan assembly or housing, it can cause the unit to overheat and lose power.
It might be a good idea to use the parts illustration in your manual or at Sears PartsDirect as a guide and disassemble the shrouding so you can clean the cylinder and fan areas. If the unit is running with restricted fuel flow it can also cause overheating. If the spark plug looks dry and white after some use, rather than slightly wet or tan colored, then you still could have something restricting fuel, possibly a partly blocked fuel line or tank vent or something plugged inside the carburetor itself. The issue might even be engine related. Check if you still have spark when the unit is hot and stalls out. Sometimes an ignition coil or even a spark plug can work fine when cold and cut out when enough heat is absorbed. The symptoms could also point to valves running a little too tight and lowering compression once hot. Another potential problem that might cause low compression could be the piston rings, in which case you might also notice the unit consuming some oil during use. Both might require testing compression when cold and hot to confirm if the loss is normal, and the side valve design your 143.996000 engine uses is very compact and quite efficient but does require some technical expertise to adjustment, so you might consider consulting a professional at that point.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Jul 10, 2010
When i start up my kawsaki kx 250 2stroke with the choke on it revs real high until i push it down is this normal
Yes.... try to turn the choke off as soon as possible after start, a cold motor reving hard is not a great idea!.
Cheers.
Nov 29, 2013 | 2007 HM CRE F250R
High rev at cold (winter cold!) idle
Your toyota technician should know what a "cold starting solenoid" is. It is the little thing that works your throttle until the motor warms up and something else takes over. I'd suggest going to another technician.
Nov 28, 2013 | 2003 Toyota Corolla
Ef 2400 Is Yamaha generator Over Revs
Take it to a dealer, there is a solid state module inside that controls the charging and idle, also a wiring diagrams are available with owners manual, go to Yamaha web site also..
Apr 12, 2017 | Yamaha EF2400iS Portable Generator
I have a Weedeater brand weedeater that needs the carburator adjusted. I am not sure how far the adjustment screws need to be turned out. Can you help?
Start with about 1 1/2 turns. Then, when you get the motor started, hold the throttle to full and adjust the screw until the motor revs up and evens out. Likewise for the low speed. If you give it the gas and it dies or stutters, turn the other screw slightly 'til it revs up without hesitation.
Aug 15, 2010 | Garden
Ariens zoom 1640 was running fine until I shut it down and when I tried to start it again this morning it turned over but would not. Any ideas ?
I have a ronning motor for a spa td-8419m23 (900)
the brushes have gone any ideas where i can get new ones from please.or a new motor?
Jun 26, 2010 | Garden
Engine cutting out intermitantly at high revs. Gets worse as engine gewts hotteR. the only coincidental is Ihave just put new rings in and it has started since then. Any Ideas - Andy
Most likely, your main jet nozzle is clogged- causing the engine to starve for fuel at high revs. Remove carb, take the bowl off the bottom and locate the main jet. The main jet is screwed into the main nozzle, which you can't see until it's removed. Remove the nozzle(brass tube with holes down sides that your slide needle goes into) and clean the nozzle and jet thoroughly. Its a good idea to do the rest of the carb the same way while you're at it. Replace the carb. If the carb adjustments haven't been messed with, this should put your little katoom back screaming again.
Jun 10, 2010 | 2002 KTM EXC 200 GS
Motor does not change for long grass , it cuts out, instead of automatically increasibg the RPM - Talon Motor Mower
i have a talon lawnmover starts get but revs are low ,i move choke up and down doesnt change revs anymore
Nov 29, 2009 | Talon Electronics - Others
Start the lawn mower and the motor revs real high.
1) This time of year with all the leaves and debris, a piece of debris might have found it's way around the outside of the carb and is caught in the throttle-butterfly linkages.
2) I have experienced the throttle butterfly screws being loose inside the throat of the carb
3) And the worse case senerio, the govenor gear inside the engine is broken.
*Check the easiest external things first, could just be debris.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 23, 2009 | Garden
Engine revs high then low then stops
check the governor lever. it prob sticking or gone.
Aug 04, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
