Question about Vacuums
Can anyone help im looking for a switch for milwaukee sawzall reciprocating saw corded 110 sspe 1000 qx
Click on this link below and enter the model number and the part you need to view prices:
http://www.milwaukeetool.com/PartsAndService/PartsPricing/Default.aspx
Posted on Jul 10, 2010
  • christopher woodger Jul 10, 2010
    hello is there anyone in the UK or do i have to order via USA
Schematic m12 circuit board
Also looking wiring schematic M12 Milwaukee charger
Sep 27, 2016 | Milwaukee tools Milwaukee Electric Tool -...
How to properly wire the cord at the switch on Oreck XL Pilot Series? Wired it wrong during a cord replacement at the switch. I couldn't remember which prong to put the black wiring on. Switch has 3...
Joanne, when you take the screws out of the handle, and take the handle half off to expose the switch, the black wire from the handle cord goes on the front terminal on the switch that is by itself. The black wire from the power cord will go on the terminal that is facing up as you look down on it. Hope this helps!
Jan 23, 2015 | Oreck Vacuums
I have a Fantom Twister Vaccum whose on-off switch is inoperative
The screw may be from underside of body where switch is and may be the reason for inoperative switch. Or switch is bad, or bad connections, or cord and or cord plug problems.
Jan 19, 2015 | Filter Vacuums
How do get electrical cord to vacuum replaced?
Look, don't try to do it yourself. This is serious. You need it looked at by an electrician, otherwise it could be very dangerous to use if you attempt to fix it yourself. Honest!
Oct 16, 2014 | Miele Vacuums
How do I replace switch on Milwaukee 5378-20?
You have to take a paper clip and stick in the hole with the wire. Pull the wire out after the paper clip releases the connector spring in the switch. Do one wire at a time to connect so you can connect the right wires to the new switch properly.
Jul 18, 2014 | Milwaukee Hand Trucks REAR HANDLE...
My corded sawzall stopped working
Check the switch, internal wiring, and the power cable.
Feb 19, 2011 | Dewalt Cordless/Corded Wet/Dry Vac 2...
Acin and sparkin
HI
Im guessing its a break in the cord where it goes in by the switch
Feb 18, 2009 | Fantom Vacums FM740 Twister 300SE Bagless...
Vacuum does not power on
Check to make sure the front nozzle is on correctly and also the bag base, make sure it is pushed all of the way in. There are safety switchs at these 2 spots and have to be engaged to work. You can't tell by looking at the cord to know that it is ok or not. Use a continuity meter to check that one side on the cord isn't open. Could also be a bad switch, carbon motor brushes not making contact. Armature bad in the motor. So there are several probables for it not working.
Mar 05, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G6 no power
Could be the switch, I would check the cord 1st. It has 2 wires running thru it, one may be open. That power cord goes bad often, if anyone is pulling on the wire rather then the plug, then it would have have stretched and break.
Jan 15, 2008 | Kirby G6 Bagged Upright Vacuum
No power
There is a safety switch in the motor area that, if not engaged correctly, can result in your vacuum not running. The most common thing that's wrong is that at the bottom part of the motor, where the cord plugs in, the cord is in between the motor and the plastic holder for the bag and it's not letting the bag click on all the way and so it's not pushing in the safety switch enough for it to turn on. Also, you may want to remove the head and reattch it and make sure it's lined up properly. If none of this works, then you could have a cord problem or your safety switch might be out. These are very fixable problems. Find your nearest vacuum repair shop. A cord should cost no more than 30 dollars and a switch with labor will cost around 80 dollars. If you can't find anyone, contact us at 1-866-509-1952 and we can help.
Apr 19, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
12 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
