Question about Vacuums
The power nasal has stopped working. I have checked the belt and is it fine. What could be the problem?
  • betharvin Apr 19, 2008
    My sweeper is a Filter Queen brand.
    President:
  • 1,673 Answers
Check the cord going to the power head, if it is ok, then you may have a bad motor.
Posted on Apr 20, 2008
I have power and air suction, but the beater will not turn and the belt is fine.
Check that you are getting power to the brush roll motor. Many Rainbows have a reset button on the power head.
Jan 31, 2014 | Rainbow Vacuums
(hover whisper cyclone)brush stopped rolling checked belt and looks fine what else can it be?
check other side from belt may be a little jam on the rollers on the oppsite side of the belt
Sep 27, 2012 | Vacuums
Ive changed the filter and checked the hoses but vacuum doesnt pick up ...when its on the dust is being blown out the bottom of the vacuum....i took the canister off to test the suction its fine...also...
have you check the roller brush and drive belt? It may be your belt has broke or is slipping and therefore not turning the brush.
Turn on machine and power head see if brush is turning if it is put a small amount of pressure on the roller. If it stops turning replace the belt
Nov 18, 2009 | Kenmore Vacuums
Henry Turbo head not working
Check the belt. see if its off the roller or if it snapped. Also, their might a reset button on the power nozzle, look for that and hit it.
Aug 24, 2009 | Henry Numatic "" Canister Vacuum
Hoover Vacuum works, then stops in 3-5 mins. Works again in a couple of hours
sounds like the motor is overheating .check and see if the brush roller is turning when its on.if its hard to turn or won't turn at all take it back where you bought it and insist on a new one.my thoughts on new items is if you buy something new then it shouldn't have to be fixed.insist on it.please leave feedback...pete
May 04, 2009 | Vacuums
Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Mar 24, 2009 | Miele SEB 213-2 Vacuum
Powerhead on rainbow not working
If the motor is NOT running - press the red button on the nozzle (assuming you have the model with the button on the nozzle)
If it stops working as soon as you release the button - you need a new circuit breaker. If Motor in the nozzle works but brush does not spin - you have to replace the belt.
Good Luck
Nov 20, 2008 | Rainbow 75th Anniversary Canister Vacuum
Rainbow SE power nozzle
If the brush is spinning ok, and the belt isn't slipping, then probably the circuit breaker is bad, or the motor is causing the problem.
Oct 23, 2007 | Rainbow 75th Anniversary Canister Vacuum
Scooba doesn't put watter. Pump not working?
I calledthe company and they told me to forcefully flush warm water repeatedly through the valve that is just  above  the brush release button the the mechanical part  of the scooba.  It may take 20 or 30 flushes (I used a turkey baster, iRobot suggested a children's nasal syringe) and "Scooby" is  running great.
Jul 28, 2007 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Vacuums Logo
55 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
