Question about Logitech X-220 Computer Speakers
My bass makes a crackling noise it never used to have this problem, i put this little faggy magnet near it and i think its the cause
  • mattymatty22 Jul 10, 2010
    no its still works its between 40hz and 50z it does, when i play a song with the same continuous bass it cracks at some points and then it doesnt
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 73 Answers
The problem is that the cables maybe snapped or the screws has come loose just try them and rate me :)
Posted on Jul 11, 2010
  • 1,940 Answers
Sounds like you turned your system up beyond it's capabilities... aka blown woofer. Buy a new sound system from www.pcrepairshop.org and that crackling noise will be gone for good, guaranteed!
Posted on Jul 10, 2010
Crackling noise on Uniden digital 5.8 cordless phone have tried moving to another outlet but same problem
Hello ,
Its a common problem in uniden phones ... try resetting ur phone once ...
Mar 26, 2008 | Lands Phones
What causes crackling in speakers? I have Bose 501's and one of the 8 inch is crakling during lower tones.
The usual cause is that excess power has been sent to the speaker cooking out the voice coil which will then rub the magnet pole pieces.
A less likely cause is contamination in the speaker.
Driving high power to the speaker will deform the voice coil. DO NOT believe what the manufacturer rates these speakers. You need to use an amplifier with no more capability of output than 1/4 the rating.
For the 501V speakers each side amp should be rated at no more than 25 Watts to each side.
Very loud bass notes at higer levels will make quick work of these speakers.
The cure is to have the speaker "re-coned" at a speaker repair facility AND use smaller amplifier driving them.
May 09, 2010 | Bose 501V Speaker
Our speakers are making a crackling/ popping noise
there is some problem with the speakers or u have got some electromagnetic field near to your speakers.
try keepng the cabinet, mobile,or any such eqiupment away from the speakers . the electromagnetic waves created by these stuff effect the magnet in the speaker
Jan 13, 2010 | Dell AS500 Sound Bar Computer Speakers
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
The sound on my laptop has been fine up until a couple of days ago, it makes an anoying crackling sound through both internal speakers and my headphones an i know my headphones are fine,???? help me please
There are several reasons why you could suddenly be getting a crackling noise. My best guess is you have the laptop near some kind of magnetic source - maybe a cell phone? My Boost mobile phone would do this to my speakers. Is this possibly the cause?
Oct 24, 2009 | Microsoft Windows XP Home Edition
There is crackling coming from the horn as soon as the power is turned on, the level of the crackle does not alter with the volume control, the cabinet performs fine otherwise ?????
The horn speaker is wearing out. Inside speakers, there is a magnet, the speaker part is attached to a cone that slides over the magnet, They tend to make crackling noises. Try very gently to apply pressure to the horn and then release. If you hear a scratching sound, the horn will need to be replaced
Jun 27, 2009 | Mackie SRM-450 System
Polk subwoofer making crackling noises
Yea, now its time to replace it! the magnetic effect is weaken which makes the very bass low frequency sound to be distorted! You should re engergise the magnet of the subwoofer or should buy the new!
Dec 08, 2007 | Infinity BU-120 Subwoofer
PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Apr 03, 2007 | Xerox Phaser 7400/DXF Laser Printer
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
Logitech X-220 Computer Speakers Logo
304 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
