Question about Whirlpool Electronic Window Air Conditioner ACQ158XR
After five minutes ac is starts tripping again it starts for some time and stops.even we set it at 16deg temprature
  • 1,940 Answers
For beginners, 16 degrees cannot possibly be the temperature you are setting your A/C unit to... and anything below 70 degrees F you are risking freezing up your unit! Sounds like it might be a good time to invest in a new unit?
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Jul 10, 2010
  • Jeremy Moore
    Jeremy Moore Jul 24, 2010
    Make sure there are no surge protectors, batter back UPS, extension cords, etc. between the main power outlet and the Air Conditioner. This will cause the A/C to trip because it is not able to get the power it needs. Try using a different power outlet if you can.
Fuse gets hot and burns out
Small Engine Troubleshooting - Jacks Small Engines
www.jackssmallengines.com/diy/small-engine-troubleshooting/
Mar 20, 2015 - Engine Will Not Crank; Cranks - Will Not Start; Runs Rough On Low ... Engine not running (After Hot Test); Stops on High Idle; Hot - Will Not ... Paint or oilburn off. .... I have a Honda self propelled lawn mower that will not stop right away ... ends puts the motor out of time change the fly wheel pin if it's not the ...
Electric Mower will not start, trips the breaker? - Instructables
www.instructables.com/.../Electric-Mower-will-not-start-trips...
Instructables
Dec 29, 2015 | Garden
How to tun off timing light after changing the belt
with ignition turned on, using the trip switch , change the display to ODO, and then turn the ignition OFF
While pressing the trip switch,turn the ignition switch ON and hold for five seconds
Release the trip switch,then press the switch again within five seconds.The digital display should change to T- BELT MODE. Each press of the switch then should change the reset time by 10,000km increments. After setting the klms hold the trip switch ON for more than five seconds then release the switch. Check that the display has now changed back to ODO and that now the warning has gone off when the engine is started .
Dec 28, 2010 | 2006 Toyota Land Cruiser
My AC stops every five minutes and restarts after a while.
i hanve 1.5 ton window air condtioner.compressor of a.c runs for 2 min and he it cuts off after 3 min it again starts
Feb 17, 2010 | Samsung AW1293L Air Conditioner
Window 1.5 AC Problem During Day
Chack size of wire. Should be at least number 10 wire. Check loose connections. Call power company to check your voltage. This time of year in different parts of the country they have brownouts which is a voltage drop becaus of the load on the lines. Have power checked. Rus
Jun 15, 2009 | Heating & Cooling
DURING DAYTIME WHEN HOT OUTSIDE 35-40 DEGREES C, AC TRIPs off
units are not able to work properly above 90, 1.0 T not go for more than 1 room. is outside of unit clean? if not turn off power to unit then spray 409 or simple green or something along those lines of cleaners on the coil part (soak it real good) it should cover entire coil as much as possible. let cleaner sit on it for about 10 minutes then use water hose to rinse as good as you can. wait about 10 minutes then try unit - so work better.
Samsung Ac compressor stops after 20 minutes and fan keep running. Again after 10-15 minutes if ac is restarted the cooling happens for 20 minutes and compressor stops.
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Mar 15, 2009 | Samsung AW0693L Air Conditioner
Whirlpool Electronic Window Air Conditioner ACQ158XR Logo
122 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Dennis Boxerman
Donni Steen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
