Question about Insignia IS 20" TV040919 TV
I have a 20 inch ingignia tv dvd combo is TVDVD20A and i have direct tv I need to know which channel is for the video output/input as currently the screen is blue and says no signal
SOURCE: Insignia LCD HD tv with "No Signal/VGA input"
I am trying to locate the reset button and can not locate it.  What does it look like?  I took the back off the tv already, do not know if I have to take more apart.
Thanks
Posted on Jul 02, 2008
SOURCE: TV will not accept commands from remote or manually
I read other further along and found someone w/same problem. Solution was to hold display button for 10 seconds, it worked
Posted on Nov 28, 2008
RCtech
  • 55 Answers
SOURCE: 26 inch insignia dvd/tv combo
This is a long shot but, there may be a reset button on the back of the tv if not try unplugging it over night.
Good-luck
Rob
Posted on Dec 07, 2008
SOURCE: I'm simply looking for the
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Posted on Jan 10, 2009
SOURCE: my 22 inch lcd tv 720p does not receive digital signals
how much is it to get the screen of a 22 inch tv fixed
Posted on Jul 07, 2009
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
How do I hook up dvd to tv
If your TV has the standard analog audio and video inputs (yellow, red and white jacks) or for better image (S-Video rounded 4 pin jack or component video red, blue and green jacks), you'll only need the corresponding cables, and also your TV could have HDMI port (digital video and audio signals), you should use this connection, all depends of what type of outputs provide your DVD/VCR, in the case your TV set doesn't has any of mentioned inputs, you still could use the antenna input and connect its matching output from DVD/VCR , tuned at VHF channel 3 or 4.
Feb 12, 2011 | LG RC897T DVD Recorder/VCR Combo
What channel does the tv need to be on to operate the dvd player? The dvd player comes on but it doesn't recognize the button commands on the tv-do no have the remote.
channel 3 or 4. if that doesnt work switch the input on the tv. the input button might be labelled input/source/tv-video or av. if you arent getting a pic while the dvd player is playing look at the back of the tv and see where the cable from the dvd player is going into the tv. it is labelled what input it should be on. ex: video 1, etc. hope this helps.
Jul 11, 2010 | Philips Magnavox 20MC4304 20 in....
Can't record tv shows
Output of combo to input of TV, and you need the cable / antenna attached to the combo to record what you want to see.
Jan 11, 2010 | Philips DVDR3545V/37
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
RCA f20580wn 20" TV about 20 years old
Hopefully you have the problem solved.
If not, the RCA plugs, listed as input 1 and 2 are shown on channel 91 and 92.
I recommend connecting the DVD to either input. Turn on the DVD. Then run the auto programming function of the TV. It will find and program the channel for the DVD. Then use the channel up or down on the remote you are currently using and you should find a working DVD.
Hope this helps.
Rcs97
Apr 07, 2008 | Televison & Video
Insignia IS 20" TV040919 TV Logo
83 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
