Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The upper half of the display is darker then the bottom
  • 1,940 Answers
Sounds like the upper backlight tube is out.
Unfortunately, you cannot replace the backlights individually, you must replace the LCD panel, which includes the power supply. The KDL-40S2000 LCD panel part number is 1-802-059-22. It costs 805 USD at http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do, but they won't ship outside the US.
Posted on Jul 10, 2010
  • shipleyvw Jan 22, 2011
    Man, that sucks! I have the same problem.... guess I'm buying another TV.
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Upper half of screen is darker than the lower half
Its back light in LCD Panel problem, there are approx 20 CCFLs in 40" lcd panel and one or two in upper half is not providing enough light to give proper brightness so you see bit darker image.
As per Sony policy, lcd panel will be replaced to fix this issue and local tech can fix it on component level (replacing bad ccfl) if he/she agrees because its risky work.
Hope this nfo will help you.
Posted on Dec 28, 2009
Samsung led un46f6300 top half has is darker than bottom
back light is bad need open the display and replace led strips
Feb 24, 2017 | Samsung UN46F6300AFXZA - UN46F6300AF 46...
LP3065 top arrea darker - backlight defect?
what you can do is to remove the back cover to access the inverter board. probably the cause of the smell is burned inverter board for the screen back light ( ccfl ) at the upper portion of the display.you can find the inverter board near the power supply board. usually you will replaced the inverter board since most of the part get fried as will as the pcb pattern circuit board get burnt.hope this can help good luck.
Nov 08, 2012 | Computers & Internet
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
Dec 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Upper half of the monitor is darker
I would try an auto-adjust first see if that helps any, also you could try it on another PC to make sure its not your video card on your PC. Another option is to reset the screen to its factory defaults see if that does anything.
Sep 30, 2009 | Samsung SyncMaster 932B LCD Monitor
Screen split in half
Hello, same thing happened to my 10 day old 60ps60 and we called LG and they came out and put "pin tighteners" on the Y board. All they are are these little white plastic clips that the technician put on the connectors. It is nothing you can fix. Call LG
Sep 05, 2009 | LG 60PS60 60 in. Plasma HDTV
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
Aug 29, 2009 | Samsung SyncMaster 932B LCD Monitor
Screen Half darker
It sounds like your backlight isn't working properly. LCD screens have backlights that illuminate the colors produced upon their surfaces, so that you can easily see the screen without an external light source. In your case, it sounds like your backlights either aren't cailbrated, are damaged, or were produced unevenly.
There is most likely not a fix for this, though most all LCD screens have some form of light distortion. My own LCD screen is slightly brighter around the edges, where the backlights are located, but this is only noticeable when displaying a completely black screen.
Jun 22, 2009 | LG 22" FLATRON LCD Monitor
Half moon shaped lines
your convergance board is about to go out. thats what happened to mine. it will cost about 300 dollars to get it fixed
Aug 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
448 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
