Question about Lexmark C734DN Laser Printer
My Lexmark C734DN thinks it has some packaging material on the print head cover. It hasn't! What could be wrong?
I'm having the same problem, Lexmark said they would send me a new print head. But the printer had never been used so it is strange that it has to be replaced.
Posted on Sep 08, 2011
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Lexmark c734dn door closed but printer eads door is still open
Power off the printer. Unplug it, actually a few hours. So if this is at work, unplug it before you leave and plug it back just after you arrive.
Feb 05, 2014 | Lexmark C734dtn - Printer - color - duplex...
Says print head not installed
It might be possible that you have not removed the plastic covering for the print head, or potentially that you didn't see the print head in the packaging. It's not the most obvious part in the shipping materials.
Dec 12, 2012 | Canon PIXMA MP610 InkJet Printer
Lexmark 734dn error is "load more paper and continue"
Check if the correct paper type and size is set in the printer settings. Also check if the paper guides are set to the correct size in the paper tray. Sometimes, the paper sensors will not detect the correct paper if the guides are set to the incorrect size.
Aug 20, 2012 | Lexmark C734DN Laser Printer
Not printing
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Nov 29, 2011 | Lexmark Z600 InkJet Printer
I keep getting the following error on my Canon 980: C000 printer error has occurred what do i do?
C000 indicates to remove the packing material.
Remove packing material so that the print headholder can move. Confirm that the printer
is powered off.
Disconnect the power cord from the printer or at the wall outlet or both.
Open the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray
    After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already). 1.Close the scanning unit cover.Reconnect the power cord and then power on the printer.
Jul 18, 2010 | Canon PIXMA MP980 All-In-One InkJet...
How do you change the laser print head assembly on a lexmark t640n
Shenanigans!
I've been fixing Lexmark T640's for a week now and Print Heads are easy!!! Don't let someone scare you into thinking you can't do it yourself just so they get more business and can over charge you to repair something!
1. Remove side and top covers
2. Remove cover for System Board
3. Unplug 7-pin connector from System Board. It's 6-white 1-black wires.
4. Remove connectors from Print Head, should be 2. 1 in front, 1 in rear.
5. Remove the 4 screws holding down the Print Head
6. Take out print head and insert new one.
7. Install by following directions in reverse! :-)
May 04, 2010 | Lexmark T640 Laser Printer
Waste full
Here's the link to download the Lexmark C734dn User's Guide for the instructions on how to replace the waste toner box when it's already full. http://bit.ly/9syjda . Go to to Maintaining the Printer, then scroll to Page 144 for the instructions. Hope this helps. If you need more assistance, just place a comment so I can get back to it. Thanks.
Apr 14, 2010 | Lexmark C734DN Laser Printer
Canon printer MP980 error code c000 what does it mean
HiHi this code is.
Remove packing material so that the print head holder can move. Confirm that the printer is powered off.
spacer.gif mp620_removepowercord.gif spacer.gif spacer.gif spacer.gifOpen the paper output tray and then lift up the scanning unit cover until it locks into position.
Pull the orange protective tape (A) in the direction of the arrow and remove the white plastic (protective material) (C).
    spacer.gif mp980_packingbeingremoved.gif spacer.gif spacer.gif spacer.gif After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already). 1. Close the scanning unit cover.Reconnect the power cord and then power on the printer.
    Found this code on the net hope it helps you.
    All The Best: Pineworks
Jan 30, 2010 | Canon Office Equipment & Supplies
Lexmark X1185
If the ink cartridge is not empty it is probably clogged. The Print nozzles are very sensitive and cleaning attempts can make the situation even worse if carried out wrong. You can try cleaning with dry gas alcohol as it contains no water. Use a piece of leather sham or other non lint material like eyeglass lens cleaner wipes and the dry gas. Wet your cloth and gently hold it on the print nozzles allowing the alcohol to dissolve the dried ink in the nozzles. Do not rub hard or you will ruin the print head. Hold it in place for at least 2 minutes with a generous amount of alcohol in the cloth. Imm
ediately place the cartridge in the printer and perfom the clean nozzle function.
If this does not remedy your problem the print cartridge must be replaced. Hope this helps you out.
George
Jun 10, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark C734DN Laser Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
