Question about HP D1560 Deskjet Printer InkJet
I have 2 new cartridges but the printer wont work. Message says you have a problem with one or both cartridges.
  • 746 Answers
First catridges put it out and clean then and now replace them properly your message will remove and it will work properly.
Good Luck
Posted on Jul 10, 2010
Printer Ink Jet
Could be a bad new cartridge. Try putting the old ones back in, and see. Unplug the printer for a couple of minutes and try again. Make sure there is nothing between the contacts on the cartridge and printer.
Mar 23, 2015 | Office Equipment & Supplies
Epson stylus dx6000 error message e-02 have tried
Hi
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Oct 14, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Lexmark X2350 printer wont recognise the cartridge
firstly never buy a second hand anything for printers because there usually are problems to follow. What it says is true. you cartridge is probably refilled and thats almost always a bad Idea with inkjet printers you have to buy new cartridges everytime the last 1 runs out it will cost you a little more but it will save you the headaches
Jul 26, 2010 | Lexmark X2600 InkJet Printer
Cartridge is not properly installed...
The chances are that the chip on the cartridge is defective. Have you tried another cartridge? If you can, take the defective cartridge back to the vendor and get a replacement or refund. If it worked once, it is likely the cartridge and not the printer.
May 29, 2010 | Canon PIXMA iP1300 Printer
Printer wont print
Turn the printer on. Remove the cartridges. Gently clean the electric contacts on the cartridges and the cartridge carrier. Put the cartridges back in. If the light is still flashing, and your printer won't print, one of your cartridges is faulty. I suggest you go to the refill shop and consult them which cartridges needs a replacement.
Does any message appears on your monitor when you try to print something? Usually, a message saying "problem with black/color cartridge" or something similar, that's why I am asking.
Dec 22, 2009 | HP DeskJet 930c InkJet Printer
Printer wont recognize a new ink cartridge
Let's hope it is only some dirt or oil on one of he many little electrical contacts, in the printer, that touch the back of the ink cartridge, which can be cleaned with a Qtip and denatured alcohol. if that doesn't work, you probably have damaged the contacts somehow, and will need a repairman. PS- your lucky- some printers won't even print in black if there's a problem with a color cartridge.
Sep 12, 2009 | HP Photosmart D7160 InkJet Printer
Refilled ink cartridge wont work. Getting message saying ink is l
Many 'refilled' cartridges aren't refilled. Try a new c artridge and see what happens. If it still doesn't work, you need a new print head.
May 23, 2009 | Canon PIXMA MP470 All-in-One Printer
Canon Pixma MP750 Printer
try to reinstall the printer cartridge
Jan 15, 2009 | Canon PIXMA MP750 All-In-One InkJet...
My printer wont print - it had a staple in a page that was put into the paper stack. it is showing message check print cartridge - I have taken both out and put both back, but it wont change from that...
You steered me to getting two new cartridges. That worked, the error message stopped after I loaded the new cartridges AND turned the machine off, then on again. It worked after that.
cheers
Jul 31, 2008 | HP Office Equipment & Supplies
WILL NOT ALIGN-
The following error message appears on the LCD panel1.gif on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Feb 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP D1560 Deskjet Printer InkJet Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
