Question about Hobart Kitchen Ranges
How toadjust the clutch on hobart mixer M-802
  • Alirio Zambrano Jul 10, 2010
    not i already replay to get the solution to my problem I need the intruction how to fixed not user manual,i send the info to
    Mr Smith
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please see particularly page #6, 10 and 12 on first manual and for general issues please see the second manual on the links---
M802 Mixers Instructions
Use and Applications Handbook
You may also like to print them for further reference. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
  • 3 more comments
    I already changed the disc inner and the disc outer also the plate pressure and i put on the mixer when a tray to put the clutch and the 1rt speed do not work i need to adjust the arms clutch (3) and the spring release to make work and make to adjust in the Hub Spline.what level i have set the screw for the spring release and how longer i have to set the arm clutch and the ball operating. the 3 arm clutch have to be the same long and the 3 screw have to be on the same level to make work the clutch how to do those what tool i have to use a caliper o what?
    that is not de answer for my problem with mixer M-802i already replay to Mr guru Rylee Smith my problem is no kitchen Rangers my is Stand Hobart mixers M-802.I need solution Please asap thank Alirio Zambrano 021.pdf (application/pdf Objeto)
    I already send the link go tot he page 26 and you'll see the clutch description and the parts. thank aaz 1959
  • Rylee Smith
    Rylee Smith Jul 10, 2010
    Hi Alirio Zambrano great. Thanks for providing the
    link. I am working on it and will provide the solution as early as possible.
    Thanks
    Rylee
  • Rylee Smith
    The nut is required to be fully tightened with spanner
    and spring to be inserted fully in its case and after it insert part # 13 (Cotter
    Pin 3/32 x 11/4) in the space provided on top of the spring case. Please do
    assistance.
    Thanks
    Rylee
What is the weight of a Hobart mixer model M 802 3 phase ?
About 1600 LBS, and its very top heavy.
Feb 23, 2014 | Food Mixers
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
Hobart m-802 mixer won't start up
call Hobart for the correct oil any way and an elcetrican will just add more problems for yoy
May 30, 2009 | Hobart A200 Stand Mixer
Need replacement motor for Hobart M-802 mixer
Hi Dan. Two options. The first is to call Hobart and ask about a temporary replacement mixer while your original motor is being rebuilt. They'll charge you for it, if they will do it at all. If Hobart is doing the rebuilding, they might give you a better price or a free loaner.
Second. eBay often lists hobart motors for sale, you might get lucky and find one quickly. Since you absolutely must have a working mixer for your business, you might consider having a spare motor on hand for just such an occaision.
If this solution has assisted you, please rate it. Good luck! ricardok45
May 05, 2009 | Hobart Food Mixers
Problem with Hobart D300 Mixer
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Dec 11, 2008 | Hobart D300 Stand Mixer
D300 hobart mixer
i have a spare unit for dsale 1500.00 cdn
Sep 19, 2008 | Hobart D300 Stand Mixer
Hobart M-802 mixer
Your overloading the mixer with too much product or not enough water,cut the batch down,the motor protection board is doing its job by shutting off.
Aug 06, 2008 | Hobart Food Mixers
Kitchen Ranges Logo
215 people viewed this question
Top Hobart Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ka4iup
ka4iup
Are you a Hobart Kitchen Range Expert? Answer questions, earn points and help others
