Question about Tripp Lite AVR550U (AVR550U-EA) UPS System
How do I set up my Ups? When I try to test it, it turns everything off. And when the power goes out, it shuts off everything.
  • 1,940 Answers
You must install the software that came with your UPS on the computer that will be connected to the UPS, either via serial or USB. Within the software you can configure when to shut the computer down in case of a power failure.
Posted on Jul 10, 2010
When the input power is connected looks okay, but when the input power goes off even for 1 second, it goes to "Stand by" mode and the out put will shut down
Get rid of this UPS. I don't like Best Silicon. I have the Manual for it. You need to look into the stacks. Also sound like it set points are out of waco. Did you just replace these batteries? If you did, then you need to reprogram the stacks because they are new. I would call the MFR. Cause you need a password to get into the main menu and to change any stack you need the passwords.
Jan 16, 2014 | APC Silcon UPS System
Not Working During Power Outage
Bad battery in the UPS. To test unplug all equipment. Check outgoing power with voltage meter. Should read around 115vAC. Then unplug from the wall outlet. Check voltage again. If no voltage is present its a bad battery.
Sep 04, 2013 | CyberPower Computers & Internet
GE LP33 UPS inverter failed to start
Dear Yared,
Did you try to give the UPS some time to recharge the batteries?
Seems like the batteries have reached their cut-off voltage and are not supplying enough voltage to the inverter.
Normally the dc boos circuit of the UPS will supply voltage to the DC BUS so maybe the problem can be found in the dc boost circuit or BUS if recharging the batteries is not helping.
Let me know.
Best Regards,
Ron
Jan 22, 2013 | MGE Computers & Internet
Intex 600VA UPS No Backup
intex is worst company in ups
Jul 13, 2012 | Computers & Internet
Hi, I have an Opti-UPS ES 1000C. When power goes off, it beeps and shuts down. Everything plugged into it shuts off. It does not convert to battery power. What's wrong?
The Batteries are bad. It can't convert to battery because the batteries are bad. Plug the UPS back in then pull the plug. If if goes off the batteries are bad
Sep 06, 2011 | Opti -UPS PowerES 1000 UPS System
Powerware 9125 power problems
Most modern ups units will not start at all without the batt, so disconnect the extra packs beg, borrow some new or old good batt blocs same spec as the original internal ones, as this is just a test any set of batts that is just ok will do.
fit them to the ups unit and see if it will start. if it will then you will need to replace all the batt blocs in the whole system.
If it does not start then the ups is faulty.
If you are not happy fitting /working with batteries then get a tech to do this work for you, batteries are very dangerous, they are always live and need to be handled with care at all times.
Hope this helps, thanks for asking FixYa
Jul 28, 2009 | Eaton Powerware® 9125 UPS System
Unit does not back-up (stay on-line at all) when power goes out.
If the battery is over 3 years old then it most likely needs to be replaced. Since it works fine except for when it is relying on power from the battery, then a new battery should make it just like new. http://www.batteryinternational.com/ups-batteries.html should have the battery you need. Hope that helps.
Apr 16, 2009 | CyberPower 525SL (CPS525SL) UPS System
ONLY 2 MINUTES MAX OF BATTERY BACK-UP TIME BEFORE EVERYTHING SHUT
you can program your power bottom to hibernate, and connect the screen direct without the UPS, so you get more time...then when the electricity goes off, without seeing the screen just push the power bottom to hibernate.
Dec 03, 2008 | Minuteman Office Plus 500 UPS System
Shuts off when power goes out
replace the battery here is a battery from a decent seller http://www.refurbups.com/s.nl/it.A/id.9156/.f there are 5 phillips screws in the bottom, flip it back over and pull th lid off carefully, pull out the battery wires (they are snug) and put in the new battery and put the screws back in.
Jul 10, 2008 | Energizer ER-HM650 UPS System
Turned off my system
Well, it did just what it's supposed to do, protect your system from bad power. You probably had a power failure during the thunderstorm and your UPS shut down your PC. When you turn it back on the battery was too low and it shut off you PC again.Check your UPS software in windows, you should have an option to run a self test. But it should be just fine.
A.J.
http://www.CustomAutomaticSystems.com
Jan 11, 2008 | CyberPower 325SL (CPS325SL) UPS System
Tripp Lite AVR550U (AVR550U-EA) UPS System Logo
166 people viewed this question
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
