Question about Epson Stylus CX6000 All-In-One InkJet Printer
Can I set printer to only use black ink as am wasting other colours and having to replace them
  • 746 Answers
Yes, you can use only black it is very simple. Just command Ctrl + P and then take properties and then choose it for black & white and apply setting now. It will wok 100% greate.
Good Luck
Posted on Jul 10, 2010
Canon pixma ip1000 print black colour with gaps.
Sounds like printing nozzle problems, or the waste ink absorber is saturated. There is step by step guide to cleaning it at
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jan 23, 2014 | Computers & Internet
When I power up the BJC-85, the printer cycles through the start up process and then beeps three times and places the carriage in the replace cartridge position. I have changed cartridges and ink tanks...
The 3 beep error is a prompt that no print head is installed. The error is occurring because the printer no longer recognizes that a print head is installed. Normally , this is due to a defective print head. If you have replaced the print head with ONE YOU ARE CERTAIN IS GOOD, then the problem is in the printer. Try taking a cue tip soaked in isoprophyl ( rubbing) alcohol and cleaning the contact strip where the print head installs. The part in the printer. The area will feel flexible but you can clean it safely. Let the alcohol dry and try the print head again. If you still have the error, the only solution is a full service that involves replacing a major part of the print mechanism.
Sep 20, 2010 | Canon BJC 85 InkJet Printer
I have a Epson stylus C88+ printer. It is showing that I am almost out of ink, however I use the black color 95% of the time, but the colors are almost used up. Two questions, 1- why is this happening and...
Very Simply, yes you can replace just the black.The low ink indicator is just scientific guessing, if you get my point.I use my inkjet cartridges until they quit.After all, It's my money.
And yours.Good Luck
Mar 25, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Wasting colour inks when printing black and white documents.
your printer needs all the cartridge otherwise it will not print
Aug 13, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Why does it keep running out of color ink, while printing only Black and White?
Whilst you rarely print in colour, its important to know that you should try to print in colour at least once a week. This will reduce the risk of your colour nozzles blocking up.
Many people have gone out to replace their 'hardly used' colour cartridges when they dont work, thinking that they have dried up, when infact its simply blocked nozzles.
If you want to keep your colour nozzles and ink ready to run, just do a full colour alignment every 1-2 weeks. Minimal ink usage there and you keep your Canon MP780 running well!
Jan 12, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Immovable Cartridge & Printing problems
try to remove the front cover of the printer is 2 screews or 3 and a few clips and whit a clean cloth absorb the waste ink from the waste tank, and this is o quik fix that i use.
Oct 18, 2007 | Office Equipment & Supplies
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
270 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
