Question about Asko Dishwashers
My Esco dishwasher is stuck on the drainage cycle and won't stop. Even if I turn the dial, unplug or do anything, it just humms as though it's still sucking wather out of the dishwasher. What is wrong with it?
  • 1462 Answers
SOURCE: Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Posted on Mar 20, 2007
  • 1462 Answers
SOURCE: bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
SOURCE: Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Posted on May 12, 2009
SOURCE: Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Posted on Jan 10, 2010
  • 457 Answers
SOURCE: the dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Posted on Feb 28, 2010
New dishwasher won't wash
What noise does it make?
Jun 09, 2013 | Dishwashers
Dishwasher Stuck Mid Cycle
Jiggle the water level float sensor .It is stuck .
May 14, 2012 | Maytag Dishwashers
Stopped working-stuck in the dry cycle
Your timer motor is shot. It's located in the control panel behind your selector dial. Go to ebay or any of the parts suppliers and with the model number, you should be able to pick one up. Make sure you unplug the power when doing any work on it.
Apr 20, 2012 | Dishwashers
Error code E 18
make sure there is nothing stuck in the imp[eller, which is the pump at the front bottom of machine. ( make sure it turns freely ) also try draining the machine by way of drain hose in a bucket. if it drains this way ok then fault is waste pipe plumbing blockage. hope this helps
Jan 02, 2012 | Bosch Washing Machines
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Dishes not washed detergent still in compartment pump will not stop pumping bosch dishwasher
cycle stuck possibly..........unplug it or turn it off at the main electric box circuit breaker......wait 10 minutes and try it again.........
Feb 13, 2010 | Bosch Dishwashers
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
GE dishwasher, model #gsd4000j00bb, won't drain.
I just posted the soloution that I found for this problem to another question. I found a bone stuck in the impeller of the discharge pump. Requires that you pull the unit out turn it on its side (rather messy and everything needs to get disconected as if you were going to remove the unit from the house and install a new one). Find the discharge pump and remove the cover (I pulled a 2.5" rib bone chip) remove the blockage, button everything back up, hook it all up slide it back in and now mine works.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
Bosch classixx slimline dishwasher not running through cycle
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
