Question about ASUS Computers & Internet
I reinstalled my cpu, unfortunately, I lost all of the sound. there was a statement that no sound device. What should I do?
  • 206 Answers
Its just because the drivers were not loaded install the sound drivers from the CD that came with the PC or if using a sound card other then the inbuilt one then the CD which came with the card will have the drivers!!
reply and rate!
Posted on Jul 10, 2010
Testimonial: "Thanks 4 ur informations. It helps me to solve the problem. GBU"
Problem msi motherboard k7n2
Well you have me lost so far..........
Why?
A) No statement/s of what AMD Athon cpu\'s are used.
B) No statement of what you set the FSB to, for each said CPU.
C) No statement of are you using Anti-Static Procedures.
D) No statement that you know how to correctly line the CPU up, with the processor socket.
E) What frequency rate (\'Speed\') of ram memory are you using?
Ram memory typically operates at half of the CPU\'s Front Side Bus.
(FSB)
F) What makes you think those CPU\'s are good?
May have been static shocked before you got them, because previous owner did not know about Anti-Static Precautions.
A Processor (CPU) is the MOST susceptible computer hardware component, to Static shock.
G) How did you clean the processors, and bottom of the Heatsink?
What method are you using to apply fresh, new Thermal Paste?
Three more;
I) What jumper pins did you use for 100MHz, and 133MHz?
J) How do you know for a FACT, that the Power Supply is good?
K) What shape are the Electrolytic Capacitors in?
That motherboard is as old as the hills, and twice as dusty.
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://www.msi.com/product/mb/K7N2.html
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Post back in a Comment.
Regards,
joecoolvette
Mar 25, 2013 | MSI K7N2 (MS-6570) Motherboard
I have lost the sound driver for Intel(R)pentium(R)D CPU 3.40GHZ.i need that 1.i dont no how to free downloed it.
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
hope this helps
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000
-2120_4-10238712.html
Apr 01, 2011 | HP Computers & Internet
I want to free download sound driver for intel-r pentium-r dual cpu E2180@2.00ghz
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 22, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Sound card not recognized by the system. Had this problems since I've had to reload windows XP with a reformat drive c:
Hello.
1st Did you reinstall the sound card drivers?
they can be dowloaded from the manufacture websight.
2nd Is sound devices listed in device manager.
If not, you may need to remove panel from cpu unplug pc first.
Remove sound card and install it into another open slot.
If slot is not available put back into original slot.
reboot pc.reinstall sound card drivers.
Jan 14, 2010 | Gateway 509GE PC Desktop
The icon of sound is non active. Any sound doesn't work. Probably I have to reinstal mainboard drivers for Acer 5200 (AT008000800)... Unfortunately I've lost CD with mainboard drivers...
you cam download here
http://www.acersupport.com/desktop/html/v5200_dl.html
or
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Acer-Extensa-5200-Audio-Driver-510.shtml
Apr 03, 2009 | Computers & Internet
Hi I am ERION
Hello ERION,
this is your lucky day... we both have the same make and model of motherboard. i downloaded mine on the link below.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
you can find all the drivers you need in this link.
hope you find this post helpful... :)
Jul 30, 2008 | Computers & Internet
I have 'lost' my sound on computer. The message says that no audio output device is installed and when I do try and install one, I am told that my files are corrupt and that it could not be installed
1. Reinstall audio driver from other same board cd.
2. Open your cpu and and than unpack all things motherboard, hdd, fdd etc., than combined all things without cabinet and than install your audio driver.
Apr 15, 2008 | Computers & Internet
Sound problem and slower
At 53% your cpu is working too hard. Turn off unecessary startup programs. You can do this through msconfig.Turn off the "C" drives indexing. Check for conflicts in device manager. Make sure that you have the correct and updated sound driver for your audio card.
Mar 12, 2008 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
