I have a 52 inch Toshiba rear projection tv. The bulb went out. I replaced the bulb but now the tv won't turn on. The blue light at the bottom of the tv flashes along with an orange/yellow light.
  • 3 Answers
I'd say your lamp fan is bad
Posted on Jul 10, 2010
Why will my Panasonic 52 inch rear projection will not turn on?
I had a 50 inch projection tv and when the bulb would go out there was always a popping sound. I went on ebay and found a new bulb at half the price the tv maker wanted. I would replace the bulb. If that is not the problem then you will just have a spare that will be needed at some point.
Apr 26, 2014 | Panasonic PT-52LCX66 Projection Television
Wont turn on red light in front flashing
You've got to replace the bulb. I've had my KF-50WE610 for four years. Mine just went out again too. This is the third bulb in four years. The bulbs are expensive too - $100 -$200 each!
Dec 03, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Turns on and off then back on then off
Discovered bulb had blown out.
At power on button, red light and green light flashed and no picture was present. I opened side panel after unplugging tv and let the bulb housing cool, then removed the bulb and discovered it had blown. Luckily I had a replacement bulb from the purchase, replaced it and it worked again.
Oct 01, 2009 | Toshiba 52HMX84 52" Rear Projection...
Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Sep 25, 2009 | Zenith D52WLCD 52" Rear Projection...
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
May 17, 2009 | Zenith D52WLCD 52" Rear Projection...
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Jul 29, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
