Question about Briggs & Stratton Garden
Think oil ran in carb
Had mower tillted to front a while,checked air cleaner and had a lot of oil in it,cleaned , started and ran about 20 min and quit.Did I mess up carb or what did I do to it?Briggs and stratton 300 series 148cc
    President:
  • Briggs & Str... Master
  • 1,545 Answers
Try to always tilt a mower with the front of a horizontally mounted engine up in the air (head with spark plug end). This will keep the oil from going places it doesn't need to go...like into the carb/air filter area and along the valves into the cylinder head and combustion chamber (unless you get lucky and the piston is running the compression or power stroke with valves closed). You probably loaded the crankcase breather with oil which in turn loaded the carb with oil when you started running it as it vents over via a metal tube an inlet in the air filter housing.
It will take a little time to get all the extra oil thru the carb. To speed this up...pull the breather off the block (on engine side opposite the carb) and stand it up or blow it out allowing all the oil to drain out. Chances are you also need to remove the spark plug and clean it also as it probably is oi-fouled which probably caused the engine to quit in the first place.
Posted on Jul 11, 2010
Starts up fgor few minutes then shuts off
Clean or replace air filter. Ensure oil is full. 30w. Remove bowl from bottom of carb & clean. Clean carb.
Sep 07, 2013 | Cub Cadet Garden
Troy-bilt 34322 343220110815 mower will not start
Dump out old gas. Fill with fresh gas. Always use Stabile in gas. Clean or replace park plug and air filter. Check oil level. All mowers have a low oil start cutoff. 30w oil. If any grey in oil moisture contaminated, dump out old oil and refill. Check fuel line for cracks or leaking. Check primer bulb for cracks, replace if required. Clean outside of carb with carb cleaner to ensure easy choke operation. Remove carb bowl from carb, ensure float hangs down freely. float down fuel flow, float up fuel flow stops. Check bowl screw for hole thru bolt, if so clean out hole.
Sep 11, 2012 | Troy Garden
2010 model 20 hp Briggs motor. Fuel going through fuel line, but not going into carberator. Motor runs good for about 15 min, but after heating up this fuel problem starts. After cooling down for an...
Two things:
1 Is fuel coming out of the fuel line. Older mowers have old fuel lines and they tend to get weak and collapse went they warm up with engine heat. Replace the old fuel line.
2 deposits in the carb. take off the air cleaner, start it up and spray a good carb cleaner in the carb until the engine dies. Put some 'seafoam' in the gas and a little in the oil and put the air cleaner back on and start the mower and mow on FULL THROTTLE. this should claen out the carb. Yes the mower will run rough for awhile.
these two cheap fixes will solve 85 % of carb problems. GOOD LUCK
Jul 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Run out of fuel . been sitting for a couple of days, fueled up checked oil ,started, ran but was like as if choke was stuck on .its due for 100hrs service but cant get it in for another 4 weeks . cleaned...
Sounds like when it ran out of fuel it sucked up some dirt at the bottom of the tank.you will have too take carb off and clean it out and make sure float is not stuck.I hope this helps.
Dec 08, 2010 | Garden
Briggs stratton,16 H>P> runs smooth 'til mower is engaged.
Is the choke staying on perhaps? check spark and plug check airflow, get compression test maybe the oil/compression rings giving way... sounds like its getting hot and increasing fuel flow for some reason??? perhaps clean carb with some cleaner while running (remove air cleaner) spray directly into carby while running run at full throttle as you spray it will try and die ... relax on the spraying and see how it goes.. check air cleaner for blockages as the same time :) hope you get it working!
May 04, 2017 | Briggs & Stratton Briggs Stratton Vanguard...
Craftsman 16.5hp 42 in. Mower runs for about
mine always starts-- and won't start again if I turn it off- going to try the flywheel key replacement-- which affects the timing-- otherwise-- let me know what you find out as a solution
May 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I hev a briggs & Stratton 5.25hp lawnmower and
I would need the engine numbers to tell ya what to do for sure. It sounds like the engine is too full on oil. Check oil levels carefully.That engine capacity is only 1 pint/16 to 20 oz's ALSO you friend may have cleaned under your deck and turned the mower with the aircleaner DOWN. That causes oil to flow from the crankcase into the air cleaner and muffler.That aircleaner is a dry paper and should not have any oil on it, If this is the case then the oil accumulated in the muffler will burn off in time. Oil soaked paper aircleaners will cause this engine not to start.IT CANT BREATH
Oct 21, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Over filled oil yzf 450
Open the air box,clean it from extra oil,renew the air filter if you have to and without the air box-air filter (or opened) try to start the bike while sraying with a carb cleaner spray through the air box towards the carbs.Don't spray too much.Little bit each time and do not twist the gas grip.Choke it too if you want.It may help.Of course before all that set the oil level to normal.
May 26, 2009 | 2004 Yamaha YZ 450 F
My Mower won't start for more than 8 sec. I changed the spark plug, gas, oil, etc. I cleaned it inside and out including the carb. left in rain for 5 min accedentaly, cleaned, na da. Help. Thanks Craftsman...
the problem is that your carbeurator is gummed from from sitting idle all winter with gas in it. Get an aerosol can of carbeurator cleaner, remove the air filter and give the air intake two squirts of carb. cleaner. Then start the mower. When it stalls again let it sit for an hour while the carbeurator cleaner works at dissolving some of that gum. Repeat the process until the mower runs again. Sometimes there is so much junk in the carb. that you have to remove it and soak it in cleaner for about three hours, and then rebuild the carb. with the proper little kit. hopefully you won't have to take this step.
Next fall let the mower run out of gas and stall then you won't have the gum in the carbeurator in the spring.
May 23, 2009 | Garden
Garden Logo
381 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
