Question about HP Officejet 4355 All-In-One InkJet Printer
Why does screen say "no scan options" when I push scan button?
    President:
  • 1,138 Answers
Re-run your installation cd. There is a procedure that you have bypass.
Posted on Jul 10, 2010
The message no signal is bouncing around on the screen
go to the tv menu.
From there it will have options.
Go to the one where it says channel scan or signal scan.
Run the scan.
It will take around 5 to 10 minutes.
That should fix it.
Feb 09, 2014 | Envision L32W761 32 in. LCD TV
How to scan more than 1 page at a time
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. Open HP Solution Center with one of the following methods:
  1. Click Start , click All Programs , click the HP folder, and then click HP Solution Center
  • Double-click the HP Solution Center icon on your desktop. A "Scanning from..." screen displays to prompt for scan settings. If this settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. Click Scan Settings , and then click the appropriate option from the popup menu: Scan Picture Settings or Scan Document Settings .
    3. Select the check box, Prompt for settings at the time of scan , and then click OK .
    4. Click Home , and then start the scan again.On the "Scanning from..." screen, click the appropriate option under "Scan Shortcuts" on the left. Each shortcut has a default group of settings that display when you click it.
  • Click Change Settings , and then read through the drop-down menu choices for all of the settings for the shortcut, adjusting any settings as necessary. Also click the Advanced Picture Settings button and the Save to file Save Options button to view your choices and make any changes. Important : HP Solution Center versions and options vary, depending on your printer. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  • Click Scan . The preview screen might display, if you selected the option to show a preview. Use the options on the preview screen to make any desired adjustments before you finish the scan.
  • After the scan completes, it goes to the destination that you specified in the settings.
  • Scan Button: HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want. NOTE: The steps to set up the scan button on your printer can vary depending on your printer model, and the version of software that is installed. For specific instructions, click the Help button on the home screen or settings screens in HP Solution Center.
    Dec 04, 2010 | HP Officejet 6310 All-In-One InkJet...
    How to stop SmartImage from 'Scanning' My screen?
    Push the first button (begining from de bottom) five seconds and the option smartimage set to off.
    Nov 13, 2010 | Philips 220CW8FB 22" LCD Monitor
    If your scan button does not work on printer,is there a key on your keyboard to push?
    Some keyboards offer short cuts that can vary, but it would still have to be configured before it would work. I think I know why you have asked this question, and where your trying to go with this so let me cut to the chase and see if I can help you get your scanner to work. OK?
    When you buy an all in one machine (which is a printer that has other options like fax or scan) and connect it to your pc, you can control the features from both sources. That means that you can push the button to scan on the printer to get it to work, or choose the scan option in the software installed on the pc to do the same thing.
    How do you use the "scan" function?
    If you want to scan by pushing the button on the printer, you need to configure the options in the printers menu that tell it what to do and where to send the image before it will work.
    If you want to scan by clicking on a button shown on your computer screen, then you need to install the printers software to configure the options and make it work.
    So which one do you want to do?
    I can walk you through configuring the scan options on your printer or help you locate the software to install on your pc and explain how to use it to scan.
    Regardless of the choice above, you will need the printers drivers installed and the software too. So first question would be, do you have the software and is it installed? Is the printer connected to your pc and does it work alread? Do you have the drivers/software already? Do you need them? If so, go to Dell's website and download them and install them to your computer (disconnect the printer from the pc first and dont reconnect it until told to do so during the installation) and let me know if and when your ready to continue and we will make this work ok?
    Oct 28, 2010 | Dell 810 All-In-One InkJet Printer
    Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
    Please clarify a few things for me so I can help you solve this issue.
    Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
    OR
    Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
    If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
    There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
    To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
    Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
    Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    How to scan using hp j4580. Booklet only tells how to fax!!!!
    1. Open HP Solution Center with one of the following methods:
      • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
    3. Use one of the following methods to start the scan:
      • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
      • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
      A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
      2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
      3. Start the scan again.
    4. Read through the various options for the scan settings. Make selections for at least the following items:
      • Scan to: Select your scan destination from the drop-down list.
      • File Type: Select the file type from the drop-down list.
      • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
      • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
    5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
    Jul 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
    How do I use my Ricoh Aficio 1035 for scanning and can it be sent to my computer?
    Yes you can use it for scanning to your computer. You must have the scan option installed to do this. Does the left side of your operations panel have a button labeled scanner? If so and you push it, it should give you the scanner operation screen. If all this is true then all you need to do is have someone setup the machine on your netrwork for scanning.
    If you do not have this button or if you do and you push it says this option not installed then you will need a network print/scan kit. You can find these on Ebay for less than $200. Installation and configuration will cost you another $100.00 to $150.00
    Oct 22, 2009 | Ricoh Aficio 1035 Copier
    Hp6280c does not list computer in scan options
    Click Here and follow the instructions to add your computer to the scan destination options.
    Apr 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Printer screen says waste ink near full
    Manual Reset procedure Waste Ink Tank for Canon MP390:
    1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
    2. Select Test mode (must be the last available selection).
    3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
    4. The menu will now say EEPROM Clear
    5. Select Ink count which is option (0) and press set
    6. Press Stop/Reset Followed by the power button and then wait for it to restart.
    hope it helps
    cheers
    Mar 31, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
    Printer won't scan a picture
    I had the same problem, but I was able to scan my first photo today. If you are using Windows Vista and have Windows Photo Gallery on your system, you should be able to scan your photo/documents. Open Windows Photo Gallery 1. Click File, and then click Import from Camera or Scanner.
    2. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
    The rest should be self explanatory. Good luck!
    Jun 17, 2008 | Canon Pixma MP500 All-In-One InkJet...
    HP Officejet 4355 All-In-One InkJet Printer Logo
    64 people viewed this question
    Seeker5211
    Seeker5211
