Question about Fellowes (R) OD1500C High-Performance Personal Confetti-Cut Shredder
We have a Fellowes Shred 1216 - both plastic gears have breaks in them - Are replacements available? If so what is the cost? and is there anyone in the Victoria bc Canada area that could replace the gears?
4 Suggested Answers
SOURCE: Broken plastic gear tooth - Fellowes P55-C Shredder
hi,
i had the same problem on the fellowes fs5m model. i opened up the machine and found that the plastic gear was completely worn on one side.
i just found this website online for spare parts: http://www.wheelermachines.com/fellowes_parts.htm
haven't called them yet. if they don't have it i might try the belzona compound.
good luck,
marie
Posted on Nov 02, 2008
  • 6 Answers
SOURCE: will not shred, but will go in reverse
Sorry don't mean to point out something obvious, but are you being shown any indication lights that the waste basket is not seated correctly in the bin or the head? If not, then you may want to try and check these connections anyway. Lights can burn out.
Posted on Aug 22, 2009
  • 610 Answers
SOURCE: My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Posted on Nov 16, 2009
57cs replacing gears
Fellowes Shredder Manuals
The above link is for the manual for your machine.
As to the cost, you will have to call Fellowes for that info and phone numbers are in the manual.
Sep 13, 2014 | Fellowes Office Equipment & Supplies
My Shredder W11C stopped working suddenly both forward and backwar. The power source is O K.
if you can hear the motor working but the paper won't pull in and shred then you broke a tooth on the plastic gear. This happens when you try to shred too much at one time. It happened to me but I couldn't find a plastic gear or the company to replace the gear. I liked the machine so I made my own tooth with DEVCON home plastic welder. With a little ingenuity and some tools you could try to fix it. Or like someone said buy a new shredder
May 07, 2014 | Fellowes Office Equipment & Supplies
My paper shredder has stopped working. There is nothing jamming it - what should I do?
I had this same problem on one machine i repaired and when I took off ththe top cover it had a bad gear where it was split and it would run fine backwards, but not forward. the gear is available online. it was also
clogged with paper, which must have caused a lot of torque on the gear. they are plastic, so they will break instead of really messing something up. good luck
Jul 24, 2012 | Fellowes P-48C Cross-Cut Paper Shredder
Plastic gear is stripped in my shredder.
That is a fairly common problem with shredders...
However most do not have replacement parts available and those that do are often more costly to buy and replace then the machine is worth..
heatman101
May 09, 2011 | Fellowes P58CS Cross Cut Shredder
Nov 15, 2009 | Fellowes 3011001 Shredder
Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Feb 13, 2009 | Fellowes Powershred SB-85C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
May 16, 2008 | Fellowes DM8C Cross-Cut Shredder
Makes a buzzing noise and won't shred. This is a Royal 140 cross cut shredder.
There is something causing the motor to not run properly. My guess is that the shredder gear (one of them) has a tooth stripped. If it is under warranty, call Royal. If not, carefully open up the unit to inspect (unplug it of course). I had a Fellowes PS400 unit and the plastic gear had a tooth broken on it. Fellowes was never able to solve the problem so I trashed it
Mar 08, 2008 | Computers & Internet
Fellowes 220c-2 gear or shear pin?
The Fellowes 220C-2 has a history of gear breakage. I've replaced dozens of them. Not a major operation. They're made of plastic and break way to frequently. Replacement requires that you remove the cutting block and it's held in place by 4 nuts threaded onto studs that require the deep well socket to remove them. I'd advise letting a professional handle it. The gear costs about $12-15 and most Fellowes dealers have them in stock.
Let me know if this helps.
Aloha,
Bill Monroe
Oct 16, 2007 | OfficeMax 0M96431 Shredder
Fellowes (R) OD1500C High-Performance Personal Confetti-Cut Shredder Logo
213 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
