Question about Homelite Mighty Lite Lawn Trimmer
MY HOMELITE STRING TRIMMER UT21505 PRIMER BULB LEAKS. MY PARTS LIST DOE'S NOT SHOW THIS PART. CAN I PUCHASE IT OR DO I HAVE TO THROW IT AWAY
    President:
  • Homelite Master
  • 1,545 Answers
You can easily get a new primer bulb for it...most small engine repair shops will have what you need, and if you want, you can most likely snag one on Ebay....DON'T THROW IT AWAY, ok?
Posted on Jul 10, 2010
Testimonial: "THANK YOU VERY MUCH. I FOUND A KIT WITH BULB LINES AND FILTERS AT HOME DEPOT FOR $6.99 "
Have a homelite string trimmer model st155. when pushing on bulb primer to prime trimmer ,wont let any gas to it. what could be the problem.
Posted on Aug 31, 2010
Why wont my homelite string trimmer start. It has spark and gas and air.
Something could be keeping it from getting the right mix of air and gas. It could be a crack in one of the fuel lines or primer bulb. Maybe the carb needs rebuilt. I made some videos on how to do all that. I got all my parts form Home Depot, except the carb rebuild kit I got from Amazon. Hope this helps.
Jul 04, 2014 | Homelite Mighty Lite Lawn Trimmer
Tip
Homelite Lawn Trimmer Tune Up
If you're having issues with your Homelite trimmer running or starting, you may need a good tune up. I got all my parts from Home Depot except the carb rebuild kit I got from Amazon. Here's some videos on how I did it. In the videos I show how to change the fuel lines, primer bulb, clean the spark arrester, and rebuild the carburetor.
on Jun 05, 2015 | Homelite Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Replace a primer bulb on a Homelite Mighty Lite 26cc trimmer
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Aug 12, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a homelite ut20585 string trimmer that i have put a new primer bulb, fuel lines and fuel filter on. i have checked the spark plug and it is good. i cannot get it to fire and run.
Ok you have to be 100% certain that you reassembled those hoses correctly, if any one of them is incorrect you are dead in the water as far as getting fuel properly. Tell me 2 things, Why did you feel they needed to be changed? and now that you've done it does the new primer bulb pump fuel at all, and maintain a full bulb of fuel after 15 min?
May 11, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Won't start
drain fuel tank. keep depressing the primer bulb until it is clear. drain tank again. remove carb cover and disconnect lines one at a time. keep depressing primer bulb to get rid of excess gas. remove spark plug an turn engine in a position that the spark plug inlet is facing the floor, pull starter rope a few times to get rid of gas in the engine chamber.
Oct 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Bgreen. Need correct part no. for primer bulb for sx135 bandit string trimmer. old one has cracked due to age.
Your SX-135 string trimmer was built by Homeliteand has a model number of UT-20601. That said, your trimmer's primer bulb part number depends on teh type of carburetor it has. If your trimmer has a Walbro carburetor, the primer bulb part no. is 01201. If it has a Zama carburetor (the most likely one) the primer bulb part no. is A01195A.
You can go to the following website to order the part: http://www.homelite.com/service_support/order_parts
Good Luck, hope this helps!
Oct 15, 2009 | Garden
I am clealning ;up a homelite string trimmer, one adjusting screw. how can i know if i have the gas lines in correct places i know which line has the filter in the tank but where does it connect to the...
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor often connecting at the bottom to a short barbed stub.
May 14, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
736 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
