Question about LG 22" FLATRON LCD Monitor
HP L1720 monitor on screen control frozen in center of screen
Contrast menu is up on my screen and can't be closed. I've held all monitor control buttons down to see if it would reset and it disapears after I hold the menu button down for 20 seconds but as soon as the menu button is realeased, it reapears. I've down loaded drivers, BIOS set back to factory settings, and looked through manuals for an answer but haven't found one.
    Genius:
  • 1,970 Answers
Mcdevito75 here, Try to simply shut the monitor off at the monitor itself, Or with your computer shut down, disconnect and reconnect the monitor to the computer.
Posted on Jul 12, 2010
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
The screen is dark and i can't even see the menu to adjust contrast or brightness.
If you can't se the menu then you can adjust it from service center.they will open it & adjust.
Oct 14, 2010 | HP L1520 15" LCD Monitor
My screen is extremely bright/white , difficult to
try to use the auto adjust button. if it doesn't work you have to go to the nearest service center in your place
Jul 18, 2010 | HP L1720 17 in. Flat Panel LCD Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
Jan 21, 2010 | LG 22" FLATRON LCD Monitor
HP L1720 flickering!
this is common, the display is bad.
all displays, fail. all do. no reason to get angry,
a broken display is worth nearly zero value $0
so how much money will you spend on worthless.?
you can get a new display at Walmart for $65, ,
lines are usually very serious. and is not ever the DC-DC inverter
a bad inverter (< it's power supply) is for the back ground lamps. not data side. the data side is failing and is common, if you twist the screen
it gets worse. ? bingo. data driver connections bad , screen.
IN most cases the part that is bad (screen), costs $100 new. or 50 used
why go there/
Jun 01, 2017 | HP L1720 17 in. Flat Panel LCD Monitor
Desktop is continuing to display contrast as 100
Dear mahendra
Welcome to Fixya Customer support
This is common problem observed in many monitors compaq,HP,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor botton circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.It deffinately solves your problem.
Good Luck
Fixya Customer Support
Chandrashekhar
Jul 22, 2009 | IBM E54 15" CRT Monitor
Monitor problem
It seems that ur control panel on the monitor having some problem...U need to take it to service center....
Dec 02, 2008 | Computers & Internet
LG 22" FLATRON LCD Monitor Logo
143 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
