Question about SGI Silicon Graphics STORAGE COUNTRY 9GB 7200RPM hard drive for Silicon Graphics SGI Onyx and Power Challenge Server Comp... (ONYXB9GB)
How will i fix my USB Drive if it does not work properly?
  • 93 Answers
Depends what is wrong. If the drive itself is not going it may be finished. Did you try to reformat it.
If it does not show up when you plug it in, then it depends what windows you are using. Some windows need a driver to make the USB drive work. That can be got from the manufacturers web site.
Posted on Jul 10, 2010
A problem occurred during hardware installation. Your new hardware might not work properly.my pen drive 8GB
hi! can u help me? i bought usb flash drive yesterday hp 8gb and it's properly working, when i create bootable usb im in diskpart in command promp and my computer got freeze not responding, im in a computer shop that's why i remove my usb flash drive and just went home. when i plug the usb it says a problem occured during hardware installation. i know there is the connection about diskparting the usb yesterday. i troubleshoot my usb flash. i go to device management and uninstall the usb drive and scan plug and play, but its not working it always show the yellow mark. even i update the driver its not working. what should i do? i hope u can help me :( here is my email just incase u have a solution for me. rk_mrace@yahoo.com Thank you very much!
Feb 16, 2012 | Electronics - Others
USB port keeps turning off
Possibility
thumb drive error. Chances are, your thumb drive firmware is damaged. So a normal laptop USB port.
Solution
To repair damaged thumb drive firmware, the solution can be found on google seach engines. Example; Fir transcends flash drive, Fix sandisk flash drive, Fix PQI flash drive, etc.
Dec 24, 2011 | Toshiba Satellite C655-S5056 NB PC w/...
My XP does not appear when connected through the USB port. When connecting it beeps. The USB controllers and hubs are all reporting they are working properly from the Deviece Manager. My printer works...
shouldn't need a driver if you got windows xp or higher. it should automatically install as a USB storage device.
is this new? if so you will need to format the hard drive if its not formatted already.
you can also check manager and go to storage device and see if the volume is getting a proper device letter.
do this by right clicking on my computer and choose manage. go to storage device and look for the hard drive. right click on it assign drive letter.
Mar 06, 2011 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
My usb port is not reading my printer cable or any of my fals drive
Seems like the usb drive is not working properly. Try to run a repair system, to see if that fixes any issues with the drivers of the usb ports.
May 17, 2010 | HP Pavilion dv9000z Notebook
The drive is not registered with my machine after I connect it.
u dont have any specific drivers that came with the Targus dvd?
..mabe the generic driver is not exepted!
..or ur usb port is not configured properly!
...do u have usb 2.0!
...did u tried on other ports!
...try to force usb 1.1!
...last step: in bios, try to putt usb dvd , or usb , (or anything similar), to boot from, (make sure u have a proper disk inside the dvd.)
if it worked (and its not simple, u need to make many tries) , then its driver problem, and in xp pro, every thing can be fixed ;)
gd luck
Dec 30, 2009 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
My flash drive wont do anything when i plug it to my computer.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
May 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
Oct 20, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
USB drive is not working - Drivers are installed.
Hi I m using Gigabyte GA-8I845GVM-RZ Motherboard USB drive is not working, printer, data cable, pen drive everying is not working but all the drivers are installed properly. Advise please. Arul selvan. M
Sep 03, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Computers & Internet Logo
106 people viewed this question
Top SGI Silicon Graphics Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a SGI Silicon Graphics Computer and Internet Expert? Answer questions, earn points and help others
