Question about Hitachi 1TB External USB 2.0 Hard Drive
Hardisk is not detcted on any computer
Hardisk is not detected on any computer
    President:
  • 1,768 Answers
1.check the USB cord
2. the controller to the USB drive could faulty.
3.the usb port could be damaged / try another port.
***I hope this helps. Have a great day!***
Posted on Jul 10, 2010
I NEED TO KNOW IF MY LAPTOP HARD DRIVE IS WORKING
Remove the hardisk and connect to another computer.if you want to know detect hardisk on your computer., you can check from bios.
Apr 13, 2012 | Dell Computers & Internet
The computer does not boot into the operating system and displays "Operating System not found."
For that problem, do this first check-up your bios setting.
Power on your PC laptop
, when screen popped up ( press F2, delete etc. ) to get into standard bios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC.
Regard.
Aug 26, 2011 | Toshiba Satellite M30 Notebook
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
Did not detect the additional sata hard disk?
Have you tried connecting the SATA hard-drive to a different computer, just to prove that it is not a "dud" ?
Is the SATA hard-drive getting power?
(It should warm-up a bit, and you make feel it vibrate as it spins.)
Have you tried a different SATA cable between the hard-drive and the SATA connector on the motherboard?
Check the BIOS settings, to be sure that detection of SATA drives is "enabled".
Apr 09, 2010 | Computers & Internet
Did not see second sata harddisk
To know if your Hardisk is detected follow this steps:
In Windows XP
1. Open Control Panel
2. Go to Administrative Tools
3. Open Computer Management
4. Double Click Storage
5. Open Disk Management
All the list of Hardisk is here, your hardisk is not formatted that's why, so you have to proceed to format just right click that unformatted hardisk and choose format, specify the label for your hardisk or simply leave it blank.
Jan 11, 2010 | HP dc7600 Small Form Factor P4 640...
Reformated my computer and reinstalled teh Dell
it means that your hardisk was not detected. you should go to the cmos/bios setup setting and check and detect the hardisk.
Apr 13, 2009 | IBM ThinkPad T30 2366 Notebook
My maxtor drive doesn't work as a slave drive. It is recognized by bios but not by windows XP
Maybe your hardisk is not compatible with xp, was it an old hardisk? Try it with other computer if it detect.
Thanks
Nov 22, 2008 | Computers & Internet
Hitachi 1TB External USB 2.0 Hard Drive Logo
252 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
