Question about Apple aluminum 13-inch MacBook laptop- Intel 2.1GHz l Core 2 Duo, 1GB 667MHz DDR2 SDRAM, 320 GB HD, ... Mac Notebook
My apple computer is locked up.. How do I unlockit.. Tried shutting it off.. And back on... But no avail.. Chriss
I have a apple iphone or smart phone its locked and ive tried to unlocked it with no luck,can you help me get it unlocked?
You will have to restore the phone to factory settings using iTunes. The when the phone is complete, sign in using your apple id and apps and phone numbers will sync back
Jul 18, 2017 | Apple Cell Phones
Unlockit samsung e1230
Unlocking SAMSUNG E1230 is very easy.Use unlock code to unlock from service provider lock.Visit the site Onlinegsmunlock.com get unlock code and unlock from network lock easily.
Aug 03, 2013 | Cell Phones
How ro make my iphone mms work on straight talk
1. From your Home Screen, Tap Safari. Type http://iapnupdateatt.straighttalk.com. Tap Go
2. Safari closes. Install Profile opens. Tap Install. Tap Install Now
3. Tap Done. Safari reopens.
4. Turn your iPhone off. Turn it back on. Make sure you turned the power off, not just put it to sleep.
5. After restart, Tap Settings->WiFi->Off
6. From the Home Screen, Tap Safari
7. Load a web page. Use a page other than Google. Google may be cached
8. After confirming data works, re-enable Wi-Fi
If your data works, congratulations! If you only need data but not MMS picture messaging, you are done. If you want MMS, continue to Method 2 - Configuring Both Straight Talk Data and MMS for iOS 6
What to do if your data doesn't work? If your data connection isn't working. Try the other Carrier APN profiles from the Straight Talk web site. You can only have one APN profile installed at a time. Each time you want to install a new profile, you need to remove the old one first.
9. Tap Settings->General ->Profile
10. Tap Remove. Tap Remove.
11. Go back to Step 1. but try this URL: http://iapnupdatetfdata.straighttalk.com/
12. If data still doesn't work. Go back to step 1. but try this URL: http://iapnupdate.straighttalk.com/
13. If you have tried all three Straight Talk Carrier APN profiles and your data still doesn't work, try the Straight Talk profile from the unlockit.co.nz web site.
14. From your Home Screen, Tap Safari, Load http://unlockit.co.nz
15. Tap Create APN
16. Tap Country. choose United States. Tap OK.
17. Tap Carrier. Select StraightTalk. Tap OK
18. Tap Create APN.
19. Tap Install. Tap Install Now
20. Tap Done
Repeat steps 4-8 to test your data connection.
Jul 22, 2013 | Apple iPhone 4S
My lava iris n320 mobile is locked by mistake how i unlock it
my mobile phone lava n320 has pattern lock i forgot my security.....how to unlockit
Dec 29, 2012 | Cell Phones
Back button on iPod Touch safari app suddenly grayed out. Tried restoring, force quit, nothing brings it back. Have to use history to navigate to previous pages. HELP!
try to turm off ur phone.. if that doesnt work then just completley waste your battery until it shuts off on its own... after a few minutes connect to the charger.
Apr 06, 2010 | Apple iPhone Smartphone
I forgot my password in iphone.how to unlockit
if you havent changed your password you will find default in manual ..you could take it to your local phone shop (sim provider)if its a simlock and they could do it for you as long as you can prove phone is yours..otherwise for phone lock email or contact iphone(can use itunes)
to update firmware or you can jailbreak it.this will not only sort your unlock prob it will also unlock it for any sim.
Sep 13, 2009 | Apple iPhone 3G
Not starting up
Hi, I' sorry to hear you are having problems,
Walter, I am confused, you say it is a brand new MacBook that shows signs of technical problems,... before installing any software program from the internet, please bring it right back to where you purchased that machine, they will be more than happy to get you back up and running.
Apple is very serious about their reputation and would hate to know that you are stuck with a non functional brand new macbook.
They should not charge you anything....
Now, if you are far from an apple point of service, and you say it is a brand new Macbook, can you reformat the hard drive without losing anything ?
If that is the case, go ahead and reformat the hard drive, or erase, the option is available to you in the installation process and then try it out, you should not have the problem anymore.
And please do not install any web program in the system other than Apple stuff to help manage shut downs or anything like that...
Well, good luck..
Apr 02, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple aluminum 13-inch MacBook laptop- Intel 2.1GHz l Core 2 Duo, 1GB 667MHz DDR2 SDRAM, 320 GB HD, ...  Mac Notebook Logo
467 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
