Question about Lakewood 200I Floor / Box Fan
Switch broken where can I get a new switch to replace the broken switch in my Lakewood box fan? Thanks- Angelica
  • 6,674 Answers
May not be identical but an appliance store or hardware store should be able to assist you with that. Home depot or Lowes as well. Take old one with you if you can.
Posted on Jul 10, 2010
Can I order new "feet" for Lakewood box fans
I searched for your solution. This is the closest I can find. This is customer service for Lakewood.
https://secure.jardenstore.com/ContactUs.aspx
Another solution if the above does not work. You could make a couple of feet from some wood as well.
Feb 06, 2011 | Lakewood 101 Floor / Box Fan
Broken grill Panels
Pls try here and look for an authorized parts distributor near you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lakewood 200I Floor / Box Fan
Can i get just the motor?
Here is customer service for Lakewood
Sometimes a replacement motor is more expensive than a whole new fan. I know, it seems a shame to throw out a whole fan because a motor is more expensive.
Feb 05, 2011 | Lakewood HV 18-c Floor / Box Fan
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
It seems like no power is going to the fan. it is completely dead when turned on
Fan is pretty simple, plug, cord, switch or motor. You can check the 1st 3 with an ohm meter. Just check for continuity, seeing if the different parts are good. If all are good, need new motor, or replace fan.
Jul 01, 2009 | Lakewood HV-12-c Floor / Box Fan
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
Cleaned a fan, now it's broken!!!
Is this the speed switch itself? These multi-speed fans have 4 or 5 wires which come from the motor which go into the speed select switch. The wiring may have the ends stripped, and this stripped end just pushes into the hole on the switch, and a little metal piece grips that stripped end.
Anyway, one possibility is to contact the manufacturer- look on their website or give them a call, see if a tech can give that info. Another poss. is to locate an identical fan and note the wiring locations on it. You can also experiment trial and error, though caution needs to be exercised here.
Jul 31, 2008 | Lakewood HV 18-c Floor / Box Fan
My Lakewood box fan fell over and stopped working
As the box fan is a simple electronic, I would take the fan apart and check the solder points. If one has broken loose or is cracked, simply re-solder the point. Test it and try again. Another suggestion would be to go to your local hardware store and find some appropriate L-brackets to secure the fan to the sill while still maintaining the ability to remove it and close the window. A little human ingenuity can probably outsmart a cat. ;)
Jun 27, 2007 | Lakewood 200I Floor / Box Fan
Lakewood 200I Floor / Box Fan Logo
195 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
