Just opened the heater/air conditioner unit on a Trane XE-70 and it does not have a filter. Questioning whether the filer goes on the top or the bottom? If possible may I have a diagram of where the filter is placed as I am a senior woman. thank you in advance!
  • 767 Answers
SOURCE: Air conditioner unit is leaking water from the bottom
Hello my name is Heath it will be my pleasure to assist you. First use a level and make sure the unit is level front and back and sisde to side. Next be sure the drain hose is not plugged or stopped by any debris.
Posted on Jun 03, 2010
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
shastalaker7
  • 1515 Answers
SOURCE: Trane Weathertron xe 1000, outside
Hi, Trane weathertron are top of the line units, and I have had extensive schooling on all tranes, commercial Intellipaks and Voyagers. If the fan has stopped, the bearings in this fan are failing and that's what you hear humming this motor or most likely the contactor. If it is easy for you to remove the fan guard ( power off ) you can turn the prop/blade and see how tight the bearings are. Carfefully, place your hand on the body to see if it is hot. If the hum is not from the motor, it will be from the contactor pulled in when in cooling mode, causing a load on it due to the condenser fan motor failing. Look on the front and rear of the motor for small caps that would be for oil. Most motors have sealed bearings now, but they still use ones that need a few drops of 20 weight oil during service of the unit. If you do, you might try going to a hardware store to get a plastic oiler bottle with the telescopic spout to reach these bearings and try to oil them for a $1.20. This may get you back on line again, only if you do have this type of bearing. Another part to check would be the dual run capacitor in the control section on the outdoor unit. Normally round and silver/gray in color, some are plastic and they look like a small can of V-8 juice with several wires coming out the top. Others are shaped like a flask without the top, lol. It will have 3- sets of connectors on it. Marked Herm., fan, and C for common. Look it over well, at the top, sides, and bottom. If you see any sings of a swollen and distorted top or body, the top swollen up, like its ready to burst, or it has and you see oil all over it, this is why the motor has failed or will not run. Replace this first as the cost is around $15.00 or so. If you have a Granger's supply, they will have them. If not, a appliance parts house. This capacitor gives your condenser fan motor and compressor a boost upon starting and keeps them running a speed at all times. If they fail, the motor could or will fail in time and so will the compressor. If it looks good, no oil leaks, you will need to have your condenser fan motor replaced. This motor works the hardest of all, in the heat plus the heat the motor gives off so its not unusual to loose this motor. At the start of summer, my crew no to stock there vans with all types of condenser motors and run caps, 1/8, 1/4, 1/3, 1,2, 3/4, and 1h.p. on commercial units. On your contactor, you will see it, it has either 1 or 2 sets of contacts on it and this is where your high voltage leads come in and connect. They will be black and some burned places. I would with power off if you have a small piece of fine sanding cloth or paper is to try and clean them up some. This is not a must. So, if all looks good, and the motor is hot, it has failed. A a/c company should charge you around $150.00 to replace this motor and they come with there own single run cap just for the motor. They will need to make a few changes on the wiring of the new motor and cap. Its around a hour to change out, plus maybe a truck or trip charge. Ask them about all charges. I am sorry for such a long solution, I just wanted to tell you a little about your unit and give you some experience. Please keep me posted and rate me if you will. I will be here if you need me for anymore help. Thank you for using Fixya.com
Sincerely,
Shastalaker7
A/C & Heating Contractor
Posted on Jul 01, 2010
  • 4736 Answers
SOURCE: trane xe 70 cycles through the gas release cycle
Either the circuit to the electronic ignitor is bad or the ignitor (electrode) itself has failed. Either are not difficult to replace, but you will need a circuit tester to troubleshoot which part(s) needs replacing.
Posted on Mar 28, 2011
h_dark49
SOURCE: Top air vent on my AC unit allow rain in. Should I cover and how?
Put the Rain Quieter pad on tap www.rainquieter.com/index.php?productID=666
Posted on Jun 13, 2012
Trane xe 900 compressor operates and blower motor stops
You need new compressor (doesn't worth to repair old one). Take a look on amazon: Amazon com Trane air conditioner compressor. I hope this was helpful. cheers
Mar 16, 2013 | Heating & Cooling
Trane xe 70 cycles through the gas release cycle but fails to ignite the burners, upon inspection it appears that the igniter isnt glowing
Mar 27, 2011 | Heating & Cooling
Had my Trane XE 70 serviced and was told I need a new ignitor module. Then was told it can't be ordered and is no longer available. Also, that no generic replacement will work with my unit. Model number...
all furnaces by national code must be 80% eff or higher whitch negated the productions of th replacement parts for such units. I tried to find a burner for that model w no luck
Jan 22, 2011 | Heating & Cooling
I have a Trane xe 70. The Heat is not turning on. The ignitor will glow but NO gas or blower. I turn on the fan and the blower does work but not when HEAT is selected on the t-stat. Also the LED light...
Check to see if you get 24 volts AC at the gas valve from the circuit board when the igniter is glowing. If yes, bad gas valve or blockage in gas train. If no, bad circuit board or broken wire
Feb 07, 2010 | Heating & Cooling
Trane XE 1200 ac The outside fan stopped
unless you have a meter youneed to see if the unit is asking the fan to turn on. if so the fan (which i doubt) maybe gone bad or the starting capasitor for the fan... is there anyway of checking the voltage to the fan
Jun 22, 2009 | Heating & Cooling
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
