Question about Philips 42FD9934 42 in. HD-Ready Plasma Television
Black line down the middle of the screen
There is a back strip approximately 6 inches wide that appears on the screen. I have tried calling repair companies around my area and the 2 that Phillips recommended, but I have not been able to get someone to help me for weeks now. Can this be fixed by someone who is somewhat technical savy or can you recommend someone in my area who would be willing/reachable to fix it.
    Sergeant:
  • 395 Answers
The problem you have is a bad PDP panel. the whole panel must be replaced by a qualified tech. if it is under warranty call philips and have them issue you a SR number, they will assiegn a tech to do the work. you must contact the tech they give and set up a pick up of the set( panels can not be replaced in home). if you already have an SR post it here, I'm sure if there is a authorized philips repair person on this sight and sees it will look it up to see if they are in your aera. most likely the repair places they gave are the only autorized repair places in your area.
Posted on Apr 19, 2008
Approximately. 2" wide vertical black line top to
You may need to adjust the resolution of your laptop to fill the full screen of the TV.
Sep 27, 2013 | Televison & Video
How do fix a hitachi tv with a 2 inch black line down the middle
try to play dvd movie first on your tv to see if the problem is on TV or the antenna connection
Jul 18, 2012 | Televison & Video
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Display has 2 inch black stripe running vertically down screen
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Dec 26, 2008 | Toshiba Satellite P105-S6104 Notebook
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Dell W5001C 50 in plasma - vertical black line
the y-boards are not the problem. its the e or f board located on the bottom of the panel open the back cover and look at both for potential burn spots around the silicon sealant. if one or r brown, theres your problem. ebay the board number and get it fixed.
Aug 18, 2008 | Dell W5001C 50 in. Plasma HDTV
Polaroid FLM-3228
cheak cables gold leads only hi end ground antenna good power strips get any magnets stuff away from it interfence ok
Feb 12, 2008 | Polaroid FLM-2632 Television
Philips 42FD9934 42 in. HD-Ready Plasma Television Logo
137 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
